dukeboy440
Odd for sure
Odd for sure
Curious what makes you think you have a low pressure situationWent off the ID number on the transmission
246609 __ (Maybe 7 4)...
Have you verified that your cables are adjusted correctly?
Do that first. You will need an assistant to press and hold the buttons as you adjust under the carGoing to run through the Park adjustment..from the TSM yet
Over on the 62-65 forum, so many guys end up having their trans rebuilt only to find out it was the cables out of wackGoing to run through the Park adjustment..from the TSM yet
PM me. I'll come up......Yeah.. that's a problem
Frank’s service and used car emporiumI think i might be playing instead of working. Moved the ramp, decided to test it. View attachment 1715962710
Buy a neighbor a beerYeah.. that's a problem
Or that lolThanks Mitch. VERY much appreciated offer
Just happens that my brother is supposed to roll through on Sunday. If he's here early enough we can knock it out.
I'll take you up on the offer to come out sometime.soon though. Cigars on the back deck
Or that lol
do you have a FSM?
So am I.......My neighbors don't move around too well. Nice guys but 20+ years my senior.
So am I.......
Great! I’ll pm you the pdf of the 1964 Service Notice that adjusted slightly the procedure. It’s basically the same as the FSM but more geared towards cables that have stretched a tad.I have the 64 Tech service manual
I was told type F would tighten it up/ give harder shifts. The transmission shop guy that helped me with mine said if it working right, no reason to use anything but the Dex it was supposed to run.Type F because reportedly it's a little heavier than Dex...
As I said… go with what ma Mopar says. PeriodThis is what makes me want to fling myself off a building...
Hey, when you drop that trans pan to change the filter, pay attention to what filter is on it. I would not be surprised to see a single hole filter. Very common mistakeThis is what makes me want to fling myself off a building...
