@halifaxhops , I took it apart and removed the very strong spring, working great now
Still a great buy for 10 bucks on Pettit Jean Mt
Buddy bought it from a dealership, then his new place has a hoist so he didnt need it. And i thought i did.I live it !! Now I want one
Ok, I thought maybe you built it, I likeBuddy bought it from a dealership, then his new place has a hoist so he didnt need it. And i thought i did.
No but I wish. It's Sara married to Chad. "It's Bourbon Night" on You Tube. Yes, she is a delight.
Ya,does it use a u-joint or that ball and trunnion setup?
I have a cable shift ball and trunnion here, no use for it, condition unknown. But it was 65 barracuda floor shift.
It will take you a long time. I count 862 videos. They are one of the most popular Whiskey channels on You Tube.Heck, I will search this out and watch it, slow day here so far, thanks brother
OK.. Did a 40 mile loop this morning. Now going to head down and see what she does on a cold start.
Late to the party. Cold start issues?OK.. Did a 40 mile loop this morning. Now going to head down and see what she does on a cold start.
Nope. 904 issues. Problems started when he replaced cooling lines....Late to the party. Cold start issues?
Change the filter?
I would drain everything and remove the valve body. Disassemble it and clean everything. Re assemble. Cost nothing but fluid and gasket. Before trans burns itself out. Might not fix it but a place to start.
You are checking fluid level in neutral . Not park. Right?
That’s what she saidFYI.... Still sucking. Grrrr...
Going to put a long story together and probably drop it into the Tech forums. May cross post here if folks have interest.
