Stop in for a cup of coffee
Might be frost out there this morning :rolleyes:
Only 8 weeks until
Morning snow birds. snow around here should start melting around here. Coffee is on and oatmeal and a banana for breakfast.
Getting my plan together for picking up Ramcharger. Flying on a Sunday and staying at a hotel in Sparks (recommended by seller), called Western Village or ?. Cheap and two restaurants, steakhouse and Mexican and it's a Casino of course. Will test drive, do paperwork/bank first thing Monday a.m. and hit the road for 13-14 hour drive. Still trying to figure out overnight middle stop, may stay at my sisters in Eugene.
Sounds like a fun trip, I like doing things like that also.
Morning coffee fans. We went yesterday and walked the Sony Open about eight miles worth both of our friends playing made the cut and will play the weekend. Today we have a Veteran Golf Association tournament we’re playing at Hickam AFB golf course. Went to the ABC store it’s like a Casey’s or Quick Trip in the states. Anyway my favorite whiskey Buffalo Trace I have a hard time finding is apparently plentiful in Hawaii go figure. Cheryl found a liquor lei she had to have. They came in several distilled flavors two bottles and two shot glasses. I told her to be careful with it haha!! Have a great day!!
Cheers to that.
Finished clearing off the bit of snow on the driveway.... Allowing the sun to dry it up.
Also, spent some time chopping up the ice sheet at the bottom of the driveway.
Thanks Mike
Problem is, those extensions will block the intake of the rear pump of an early 904.... Creating a no shift condition and causing multiple rebuilda and eventually breakage...
Ask how I know
If you think about it, no extension is necessary. The fill line doesn't change and the extra quart is in the bottom of the pan. The filter extension, if you use one, submerges the filter in the top inch of fluid. Slantsixdan pointed that out to me.
Yes.. Good point. Just have to keep it filled more....
I could pull the deep pan I already have.... Worried that it's cursed
Just fill it like normal. With it filled as designed, the filter will be submerged in the same amount of fluid regardless of whether it has an extra quart or an extra gallon capacity. The fill level never changes just the total capacity.
Bad Ju Ju with that pan? You need an exorcism it sounds! :poke: :thumbsup::thumbsup:
The pan is the one that the builder of my $1,700 door stop put on.... We'll call him "Stan". :rolleyes:
Need to burn some sage around it and leave it on a stump in the woods for 48 hours.
Then rub it down with @lkopaska Altered Transmission Spirits
Morning gang
Meter reader from the power company came by yesterday. This next bill should be a record setter.
Meter reader???
We have smart meters here where they get the data remotely... No more meter readers...
