Keep telling him there is a small market out there for it if you get the word out. Good for the winter when they are slow.
The word of the day is legs...
Help spread the word...
What do you mean the Hooters were smaller? I'd be pissed too lol!I went to Hooters last night to get my free birthday wings...
Their wings have gotten smaller...
My local bar hang out has much bigger wings than theirs and half the price... The sauce tastes similar, so no more Hooters wings for me...
This corporate cost cutting and making things smaller is pissing me off...
Why does that seem like it was an Abott and Costello conversation at the pharmacy.
That's a crazy machine, never seen one. Does it pack the wheel bearings too lol!Good morning!
I was told by a rep that the pads are more aggresive now. By the time the pads are shot the rotors are too thin to be cut. Also a lot of times the rotors are warped and cutting them thinner is just going to make it happen again faster.
We have a badass procut machine at work that cuts the rotors on the vehicle (hasn't been used since I cut the rotors on my Dart years ago)
Yeah the pads and shoes are a hard semi mettalic now.
Small Hooters matter you ........What do you mean the Hooters were smaller? I'd be pissed too lol!
No doubt.
Should be above 50F by 10. S'posed to get near 70. Want to do some garage clean-up and most the yard sale stuff is right where I left it. Think I will just drag it out a few feet further and put the sign up again...
That certainly enters into it. Shitty organic pads went the way of the dodo and we have pads now that allow for better friction and cooling with less surface area. But also modern cars are cast with less steel. It wasn't uncommon a few decades ago for the difference between nominal thickness on a brake rotor and the machine to spec to be .090.Good morning!
No I do not. I hardly know anyone here except my bandmates. I live on Quail Meadow DriveYou know the DelOssos in modesto?
That certainly enters into it. Shitty organic pads went the way of the dodo and we have pads now that allow for better friction and cooling with less surface area. But also modern cars are cast with less steel. It wasn't uncommon a few cascades ago for the difference between nominal thickness on a brake rotor and the machine to spec to be .090.
Now days many are .030 from nominal to discard.(hell its kind of tough to even come up with a spec book it seems these days)
This isn't all bad it reduces unsprung weight and contributes to better ride and handling characteristics of modern cars.
Now we also have a problem that brake rotors now days are built of an inferior metallurgy. The engineers may spec out a specific alloy but by the time the rotors are cast in a foreign "factory" they are a hodgepodge of recycled junk with no real metallurgy.
Anyone who has ever cast their own bullets can attest to the dramatic effects alloying metals can have.
You can watch the process on youtube
I haven't seen one of those on car lathes in forever. When I started wrenching those were supposed to be taking the industry by storm. They would allow for complete elimination of runout compensating for uneven mounting surfaces and all manner of imperfections. But they never panned out around here. Mostly because we could pull a brake rotor and have it machined on the old ammco faster than we could set up the on car lathe.
In a modern shop a brake lathe is almost useless although I have turned a bunch of flywheels and machined many other things that the machine was never intended for. I even once used a brake lathe to cut wheels apart and weld back together a wider steel wheel.
They run the big corn maze over there. Mike and I go back a long wayNo I do not. I hardly know anyone here except my bandmates. I live on Quail Meadow Drive
