Decided to 'take it easy' and do a little more cleanup in the garage today. Ended up working way harder than I thought. Had a leftover wheel with tire on it from the Neon. Trash will take the tire, but not with wheel. And scrap won't want the tire on the wheel. ...Thought, 'how hard can it be to remove'? Very! Couldnt pop it off the bead. I ended up cutting it and learned why they are such a ***** to get them free. Heavy steal cable around the inner edges. Pretty much killed a new carbide tooth cutter on my multi-tool getting through them, but its off.
Also took apart desk I was trying to give away. Might actually use the panels to make something else. It is pretty nice veneer over some kind of composite core material. And took another cabinet apart to a point that trash should take it. If not It can go down on the burn pile. Everything else can go to basement or to Goodwill or trash if not sold in next few weeks.
