Same backGood morning!
I had that happen a few days ago. I think for me anyway it happens when low moisture in the house.Good morning everyone. Woke up with a bloody nose, but got it taken care of right away, just up too early on a Sat. Snowing now, was raining last night about midnight. Strange.
Morning fellas. I have a few moisture meters in the house. It will get into the 10-15% range if I don't run the humidifiers. We have hot water heat so it is real dry. I always liked fuel oil heat. It was quite moist.I had that happen a few days ago. I think for me anyway it happens when low moisture in the house.
I have always preferred hot water heat over forced air except the central AC ability. I used to put bowls of water on the cast iron radiators. Helped a bunchMorning fellas. I have a few moisture meters in the house. It will get into the 10-15% range if I don't run the humidifiers. We have hot water heat so it is real dry. I always liked fuel oil heat. It was quite moist.
Running propane heat and without the humidifier it gets dry.Morning fellas. I have a few moisture meters in the house. It will get into the 10-15% range if I don't run the humidifiers. We have hot water heat so it is real dry. I always liked fuel oil heat. It was quite moist.
Hey Pete how's George doing?Good morning coffee bunch
We have 1 zone with radiators. 2 zones with baseboard fin tube and one zone with a large coil in a forced air blower case (that provides a/c in the summer). It's a unusual system for sure.I have always preferred hot water heat over forced air except the central AC ability. I used to put bowls of water on the cast iron radiators. Helped a bunch
LMAO.<~~~~ gots dinosaur fart heat here
Good to here thanks Pete.He’s doing really good considering what he went through, staples come out this coming week, medicine routine and back to school after new year
Ain't no magic number or symbols, well except for pyramids. When a carb has a pyramid shaped transfer slot, it has the great power of the bubba.So I pulled the carbs off. I was able to confirm. There are 76 jets in the primaries, no power valves, and rear metering plates are #12. I found it strange that despite the 1000rpm idle, the transfer slots were covered by the throttle plates. The secondaries were closed. So, everything I have read says the transfer slots should be visible below the blade by about 0.050" or a "square" when looking at it. Any thoughts? I worry it will idle much faster now as I had to turn the screw in about 0.100"
And close the schoolsI don’t understand every time it rains or snows the forcasters call it ‘storms’
Yes, these are 1:1 linkage on both carbs. All 8 barrels at once, within reason as there is some primary movement before secondary but not much. These are not double pumpers, 1850 style. No sure how secondary idle gets fed. I knowing I add metering blocks to the rear for jet changes, the idle mix screws will not work as the carb bodies aren't drilled for that. Does that help?Ain't no magic number or symbols, well except for pyramids. When a carb has a pyramid shaped transfer slot, it has the great power of the bubba.
For a model 4150/60 family, older Holley's should have .020 to .040" showing on the primary slots at idle.
If the slots were made wider, or longer (common these days) then there is more area...
IIRC this is a pair of 1:1 carbs on a tunnel ram. So at minimum that twice the fueling at idle than a single 4 bbl on the same engine.
I don't recall - or maybe we didn't know how the secondary idle is fed. If its through a 'snake' passage in the throttle plate, or independent...
Map out everything that is accessible. Idle Air Bleeds, Idle Feed Restrictions (if not buried in the metering block's idle up passage, etc.
Yep and not cheap.New garage door installed this morning. Custom ordered of course because of the size.
