Stop in for a cup of coffee
Yes. That was the intent...
They tried making an egglayingmilkpig that ended up super expensive and not that great at the end of the day.
I knew the f-35 has a bunch of variants. Kind of making it a joint parts replacement more accessible.
The H-60 were like that except for the different model parts. We had the MG so there was stuff not at other say army depots but the hard parts were. NASA had one a Aimes Research Center, We were co located so I got to know the two man shop there well. And we used to go to thier cafeteria every Tuesday they had great cutom burritos for $2.50 a pound! They got some weird flight control issues I used to help them brainstorm, but then again, they were trying to make a drone aircraft out of it. Tell you what the army test pilot there had to have a set of balls.
Morning!
A little colder at -6c.
Windy and snowing too. Some more filler to knock down, then firebird goes out. Guess plow truck comes in for some investigation. Im thinking distributor cap. Or ignition control module.
1 On the way!
Morning!
Whats it doing Frank?
Its got a low rough idle, poping out throttle body when revved up. It stalled and was turning over like it was way too advanced.distributor is tight. I almost thought timing chain,but it started after it cooled off.
Map sensor,cap/rotor or ign module.
Mine is a 88 TBI. Hope it is not the ecu not cheap. Not sure if it needs to be flashed or not.
Does yours take that Mopar only code reader? Mine I got lucky Matt had one down the road.
Have you seen the Blackhawk replacement?!
It literally the Marine Osprey with a V tail made by the same morons that made the shorty osprey that crashes at a rate 13 times more often than the Blackhawk and had 700 more maintenance down hours than any other aircraft in the us arsenal
I worked with a Gunny who was in the unit that had a platoon killed when they were testing back in 2000.
It kinda vibrates itself apart... especially going VTOL to forward flight
It's telling that Marine-1 is still a 53 not an Osprey
The last two days were rough, but a little better yesterday...
How are you doin'??? And how's Kitty doin'???
Glad you're seein improvement. Kitty's almost her mean old self. I'm still a little stuff up but better.
