I wonder if some lower vents and a roof vent would help?Our car club has 2 containers but we have a bit of a moisture problem, have to address that this spring
Only way have ever seen that removed is either roof vent that is motorized But that relly depends on the outside humidity level. or a dehumidifier. Thats what I will use and plumb the drain out. Run it once a week a few hours and every time I open it up and close it. Military has the same issue.Our car club has 2 containers but we have a bit of a moisture problem, have to address that this spring
You said "moist"!
Wow learn something new everyday.Its true Fred I read it on the internet!
Just an Idea Ray but I worked in a warehouse for Yamaha, Suzuki and the list goes on on .The Japanese before they put the bikes, Snowmobiles and what ever could rust in a shipping container when shipping to the states and would spray WD40 on the metal to keep the moisture off.I really need it pretty low humidity with all the distributors and parts I have that will go inn there, Hell I am prob putting 1000 sets of points in there that are early and hundreds of caps.
It must be true then.Its true Fred I read it on the internet!
Everything?Best part about having grandson this weekend is I got blueberry and pecan pancakes! With fresh strawberries! Yummy! I accidentally spilled maple syrup on everything!
Karl isn’t on I thought I was safe! Hah!Everything?
condensation?Our car club has 2 containers but we have a bit of a moisture problem, have to address that this spring
They were on stakeout watching you.I accidentally set our‘s off and was surprised how quickly the sheriff Showed up, he must have been in the area
?Bet by Tim they are cheap with the ports backed up. This is from a rail hub by Keith actually.
Nice to have separate so if you pop the breaker on the outlet you are not in the dark.Any one ever run a couple of outlets and lights in one? I am thinking metal conduit the easiest? Weld the mounting points ? Open to ideas. Tops 15 amps. 2 led lights, two outlets one near the front and one in the back for a de humidifier. Eventually I will punch a door in the side and connect it to the shop, oneday my vision of grandor.
Self tappers with rubber washer used for exterior panels. And/or silicon over each one.I am trying to avoid holes in it that can rust. Stayed in one of them a few times. Desert sucked never got below 100 in them.
Unistrut. Not cheap. Probably not worth it to mount one conduit. And you need bigger fasteners and holes to mount the strut than for directly mounting the conduit.I am thinking thoose channels IT guys use to hold wire bundles. Just long enough to clamp say 1/2" conduit?
If you spill too much syrup, you may need another pancake or two to soak it up.Best part about having grandson this weekend is I got blueberry and pecan pancakes! With fresh strawberries! Yummy! I accidentally spilled maple syrup on everything!
