Stop in for a cup of coffee
Welcome to the Coffee House, Dan
I'm having a large
slice of Pizza. He'll I may just eat the whole pie.
Now the real work can begin! BTW... i have taken apart cars but nothing as old as a 62.. just WTF soooo many bolts in the front end it's insane.. only broke like 3.. and only bad rust is on the side of the cowl right behind the splash shield there is a hole... and no one can see it.. so easy fix.. i think foil tape counts as metal? :)
On a sad note.. one of those clip nuts spun and wadded a corner of my grille :( best part on the car.. luckily it didn't break anything and i should be able to straighten it.. just a bit mad..
Next step get help to remove the hood, then motor comes out.. then suspension and k-frame.. the fun stuff :)
OK. Survey of the hive mind
273 build. Stock or performance? It's a Valiant so it isn't a muscle car
stock.. unless you have to replace the cam or something.. then a tiny bump up a bit. Make a nice cruiser, which was my plan :)
please do the commando exhaust also.... it's about as perfect as a car can sound :)
Any Mack Truck collectors ?
This showed up on the porch today.
Patented too!
