dukeboy440
What’d you end up gettingNo OT today, time to try out the new chainsaw!!!
Celcius vs farenheit. I see the confusion. Here, 4 degrees overnight is warm for early spril.4 and 7 degrees and it ain't gonna be rain. Jes sayin.
Why not? Its simple. 100 equal divisions between freezing and bouling points of water.Well that don't count down here. LOL
Cause ‘MericaWhy not? Its simple. 100 equal divisions between freezing and bouling points of water.
Went with the MS362, had a 25 inch bar on it so will stick with that unless I don't like it then put on a 20 inch.What’d you end up getting
61cc . Should run that 25 inches just fine.Went with the MS362, had a 25 inch bar on it so will stick with that unless I don't like it then put on a 20 inch.
I agree it will, I'll see if I don't mind wrestling around that longer bar. Some say it's easier because you're not bending down as much, we'll see. Today I'm picking up fairly big logs with grapple and buzzing off rounds, will take longer but hey I'm lazy lol!61cc . Should run that 25 inches just fine.
Chain wise, Oregon chains are really good and affordable. Full chisel, semi, rip, skip, they make it all.
Who are YOU calling mental???Morning Metric Mentals!
Stihl chain is by far a better chain. Oregon isnt as hard, sharpens easy but dulls fast. And its best to buy the stihl files,they seem to last the longest.61cc . Should run that 25 inches just fine.
Get you a log roller. They’re about 80 bucks, but you can roll the log up on it, holds it about a foot off the ground and really helps your back.I agree it will, I'll see if I don't mind wrestling around that longer bar. Some say it's easier because you're not bending down as much, we'll see. Today I'm picking up fairly big logs with grapple and buzzing off rounds, will take longer but hey I'm lazy lol!
When we did a big cleanup here, buddys excavator had a thumb with the bucket, hold tree over dump trailer to limb, then swing over and block onto the pile. Made light work.I agree it will, I'll see if I don't mind wrestling around that longer bar. Some say it's easier because you're not bending down as much, we'll see. Today I'm picking up fairly big logs with grapple and buzzing off rounds, will take longer but hey I'm lazy lol!
Haha fired mine up the other day. It was early and we discussed the same thing. I waited until 8:30 am.Hey it's 4:20, I suppose that's chainsaw hour in some universe!
Agree to disagree. My Stihl chains last half as long as my Oregons. And cost 3 times as much. Course I only run rip chains and full chisel chains.Stihl chain is by far a better chain. Oregon isnt as hard, sharpens easy but dulls fast. And its best to buy the stihl files,they seem to last the longest.
Yeah, i don't get why my country can't handle a system that works by 10's... real hard stuffWhy not? Its simple. 100 equal divisions between freezing and bouling points of water.
One reason I still keep my ag license. 0100 is ok!Haha fired mine up the other day. It was early and we discussed the same thing. I waited until 8:30 am.
Have one, cant hook with stand, use it sometimes, can save chain in the dirt problem lol!Get you a log roller. They’re about 80 bucks, but you can roll the log up on it, holds it about a foot off the ground and really helps your back.
THat went fast.
I run both bars and chains. Like buying Oregon cause when I stick my saw in a tree felling it and I bend the bar much cheaper to replace : )Agree to disagree. My Stihl chains last half as long as my Oregons. And cost 3 times as much. Course I only run rip chains and full chisel chains.
I do have a Stihl brand bench mount chain sharpener that’s about 35 years old or so, it’s pretty good.
Archer chains are pretty good too. They’re Australian made and I only have one but it seems to hold well.
I love Stihl saws, especially the older D series which are nearly indestructible but I’ve not had good luck with their chains
I'm seeing more battery powered saws in Telecom, guys that aren't supposed to carry gas on their rigs but need to access mountain sites. Spendy but if you use it makes sense.Speaking of saws I picked up this hand held Stihl for small jobs. Battery powered works well cut 4-6” limbs no problems. Doesn’t have an internal oiler so use the oil shown here a couple drops occasionally.
