ScampMike
Despicable Damn Yankee
lunch time lurker - LOLUhhh... Yup...
there's one - what the heck do I hook my timing light to? the battery is in the trunk...You really need to make sure you have several things ready upon fire up. Have a timing light connected. Have timing very close to where it should be. A fire Extinguisher, A srewdriver to adjust carburetor. Get a box fan in place, in front of the radiator. Some extra coolant or Water. I like to start mine with just water , in case there is a leak somewhere. Most Important, Another set of eyes to look for leaks or other issues. Good Luck.
I aint done squat yet. Just ran some errands. Now need to pull the go pedal of the Poncho, so I can bend it some for "heel/toe driving"lunch time lurker - LOL
In my Pulling tractor, I put sand in the block instead of the water. The thing is, you can heat them up, but running alcohol the heat does not have much effect on the performance. Just have to let them cool off by themselves. NO water! That will crack something. I used a Blower turning HARD! Had to use copper head gaskets to keep the pressure in. They would leak coolant, so no way to water cool. But not needed in that app.how do those top fuel cars do it? they don't run a cooling system do they?
like to leave the distributor"just" loose enough that I can move it by hand, and have a wrench to tighten down.You really need to make sure you have several things ready upon fire up. Have a timing light connected. Have timing very close to where it should be. A fire Extinguisher, A srewdriver to adjust carburetor. Get a box fan in place, in front of the radiator. Some extra coolant or Water. I like to start mine with just water , in case there is a leak somewhere. Most Important, Another set of eyes to look for leaks or other issues. Good Luck.
nahh.. aluminum doesn't crack......Can you say Cracked head?
pulling tractor - something you still do?In my Pulling tractor, I put sand in the block instead of the water. The thing is, you can heat them up, but running alcohol the heat does not have much effect on the performance. Just have to let them cool off by themselves. NO water! That will crack something. I used a Blower turning HARD! Had to use copper head gaskets to keep the pressure in. They would leak coolant, so no way to water cool. But not needed in that app.
That is one of the ways Top Fuelers do it.nahh.. aluminum doesn't crack......
ah yes - the distributor one I knew - the alternator trick I like!! I might have thought of it... but probably not - makes too much sense - LOLI also
You shoul be able to get 12vts at the rear of your Alternator, and ground to the block.
Nope, when my Father passed away, I sold everything. A REAL expensive undertaking. With a drag car, you can test run it, on the street or a track. With a pulling tractor, no way to test it before you make a pull. You need a sled and who has one of those laying around? So lots of trail and error.pulling tractor - something you still do?
My neighbor pulls on the Lucas Oil 10,200 lb pro stock tractorsNope, when my Father passed away, I sold everything. A REAL expensive undertaking. With a drag car, you can test run it, on the street or a track. With a pulling tractor, no way to test it before you make a pull. You need a sled and who has one of those laying around? So lots of trail and error.
Put er in four wheel drive!01001111 01101000 00100000 01100011 01110010 01100001 01110000 00100000 01001001 00100000 01100001 01101101 00100000 01110011 01110100 01110101 01100011 01101011
I had ... none of that.You really need to make sure you have several things ready upon fire up. Have a timing light connected. Have timing very close to where it should be. A fire Extinguisher, A srewdriver to adjust carburetor. Get a box fan in place, in front of the radiator. Some extra coolant or Water. I like to start mine with just water , in case there is a leak somewhere. Most Important, Another set of eyes to look for leaks or other issues. Good Luck.
010011010110000101111001001000000100100100100000011000100110010100100000011001010111100001100011011101010111001101100101011001000011111100100000001000000110110101111001001000000110001001110010011000010110100101101110001000000110100101110011001000000110011001110101011011000110110000100001
What is it before I open it up ?
01101110 01101111 00100000 01111001 01101111 01110101 00100000 01101101 01100001 01111001 00100000 01101110 01101111 01110100 00100000 01100010 01100101 00100000 01100101 01111000 01100011 01110101 01110011 01100101 01100100 00100000 00100001 00100001 00100001
