I don't need but wouldn't mind a 426 Wedge. Maxie preferred.no 426?
Just what I tagged you and Matt @Mattax in last night or this AM. So it smokes terribly. It does have 13" of vacuum at idle, but on both ported and manifold vacuum ports. Guessing the throttle blades are too far open. The idle mixtures screws do nothing, even all the way in, runs fine. Again throttle blades open too far and allowing transfer slot fuel? IDK. Thoughts this AM pointed to maybe damaged the valley pan gasket - this could be an internal vacuum leak and the oil vapor/smoke. Also, the vacuum line that runs from the intake to the transmission vacuum modulator is a known source of smoke. If the diaphragm failed, engine vacuum can pull trans fluid (Not Bud Light @memike has a case though) into the intake near #4 cylinder. This could explain the smoke on passenger side. Plan is as follows:@71GSSDemon any new progress on the boy’s car?
Good call on the vacuum modulator. I’ve had Fords suck trans fluid up and foul plugs before. Sounds like a solid plan of attack. Keep us posted.Just what I tagged you and Matt @Mattax in last night or this AM. So it smokes terribly. It does have 13" of vacuum at idle, but on both ported and manifold vacuum ports. Guessing the throttle blades are too far open. The idle mixtures screws do nothing, even all the way in, runs fine. Again throttle blades open too far and allowing transfer slot fuel? IDK. Thoughts this AM pointed to maybe damaged the valley pan gasket - this could be an internal vacuum leak and the oil vapor/smoke. Also, the vacuum line that runs from the intake to the transmission vacuum modulator is a known source of smoke. If the diaphragm failed, engine vacuum can pull trans fluid (Not Bud Light @memike has a case though) into the intake near #4 cylinder. This could explain the smoke on passenger side. Plan is as follows:
- Change carb to the Holley and try
- Unplug the transmission vacuum hose – maybe a diaphragm is bad and possibly pulling fluid up???
- Pull oil fill cap and see if there is a vacuum vs blow by – this would prove a crankcase vacuum leak
- Pull and replace the valley pan
- Reassemble and retest
- Then if runs correctly, decide if it still needs the converter or return it
there is a member here who wanted to sell me a poly Weiand 6 pack and a Dual quad intake about a year ago. Trying to remember who he is.
Hey Karl. How goes it?There's a six pack poly manifold for sale on my local craigslist...
Mopar Edelbrock P600 318 Poly 6 Pack Manifold - auto parts - by...
Sounds like a toddy well earnedHey home from our tournament sorry I missed the party. Glad though to be an almost daily participant of the daily show here.
Went to a small town an hour away with an amazing golf course. Its rated one of the best small golf courses in Kansas.
We played well but missed out on the flight money this time.
Cheryl missed an eagle chip on a Par 4 that would of won the only skin and $500 cash.
Home to do nothing tonight but relax.
I think that's a scam. His last name begins with a B and ends with N.65 Plymouth 361 4bbl 305hp complete rebuild - auto parts - by owner...
The universe is listening
[Found!] - WTB: Poly 318 intake - 4bbl or...?
Howdy!! Anybody have a 4-barrel intake manifold for my poly 318? Would also consider a dual quad. Shy on the triple-two's but who knows? LOL I am local to Reno/Sacramento corridor, but otherwise you would need to ship it to me in South Lake Tahoe. Kind regards! Hunterwww.forabodiesonly.com
I sent him a message on FCBO.65 Plymouth 361 4bbl 305hp complete rebuild - auto parts - by owner...
So...disconnected the vacuum modulator and smoke cleared up. Win! Still ran rough so I pulled the Edelbrock carb off and put on an 850dp I had on it. After getting floats set, it runs great and is very snappy. Maybe a bit rich yet. Still wants to die when going into gear.Good call on the vacuum modulator. I’ve had Fords suck trans fluid up and foul plugs before. Sounds like a solid plan of attack. Keep us posted.
Well done good sir! That is a win for sure!So...disconnected the vacuum modulator and smoke cleared up. Win! Still ran rough so I pulled the Edelbrock carb off and put on an 850dp I had on it. After getting floats set, it runs great and is very snappy. Maybe a bit rich yet. Still wants to die when going into gear.
Thanks. I will need to get a new vacuum modulator but that is easy enough. Now just fix the die in gear issues. It runs if idle is increased. But then too fast of idle in park. My feeble brain still feels a looser converter will fix it. Worked for Demon and Dads car. Cam wants to idle faster than converter wants to slip. IdkWell done good sir! That is a win for sure!
Yep. It sounds like you need a smaller cam or a higher stall converter.Thanks. I will need to get a new vacuum modulator but that is easy enough. Now just fix the die in gear issues. It runs if idle is increased. But then too fast of idle in park. My feeble brain still feels a looser converter will fix it. Worked for Demon and Dads car. Cam wants to idle faster than converter wants to slip. Idk
In my experience vac leak is pretty rare.So Seth's car has made even more confused. Turn the idle extra screws all the way in and it does nothing different. Can't find a vacuum leak something, isn't right. Also there is full vacuum on ported port also. WTF! Has 13" vacuum at idle. So, I am wondering if getting enough fuel in carb somewhere to run and that is picking the vacuum up?? Maybe actually has low idle vacuum and the springs are allowing it to run pig rich picking idle up? This is Eddy AVS2. Going to a Holley I have tomorrow.
I dont know that Holley is magic, but any known good carb should transfer over and ran just about as good on another engine.Just what I tagged you and Matt @Mattax in last night or this AM. So it smokes terribly. It does have 13" of vacuum at idle, but on both ported and manifold vacuum ports. Guessing the throttle blades are too far open. The idle mixtures screws do nothing, even all the way in, runs fine. Again throttle blades open too far and allowing transfer slot fuel? IDK. Thoughts this AM pointed to maybe damaged the valley pan gasket - this could be an internal vacuum leak and the oil vapor/smoke. Also, the vacuum line that runs from the intake to the transmission vacuum modulator is a known source of smoke. If the diaphragm failed, engine vacuum can pull trans fluid (Not Bud Light @memike has a case though) into the intake near #4 cylinder. This could explain the smoke on passenger side. Plan is as follows:
Thanks as always Matt. The smoke has cleared up now with vacuum modulator disconnected which to me proves it was failing or failed. It helps that I understand Holleys better and that my be the only part. But it runs well, may have to play with an air bleed like the Demon if needed. I bumped up initial timing but then it didnt want to start, So i backed it down until it would.Get the idle down to something reasonable for that combo. Then decide.
