One time use? Prior stretched would be my guess.They may have been pre-fooked
Glad you are feeling better buddy!My first job was working in an orange juice factory, but I got canned because I couldn't concentrate.
3 inches. I used it to do the other 6 injectorsYep, that's pretty tiny. How long is your shortest 1/4" ratchet or combination wrench?
Supposed to be reusable.One time use? Prior stretched would be my guess.
Possible I supposeThey may have been pre-fooked
Grocery store run. Something I need to do today.
Gives me direction as well as motivation.
Pretty fancy ones. I can see why the price.Decided to go aftermarket. Ordered. Man that sucks paying 48 bucks after shipping but ouch I needed it.
Sumptin don't look right.They may have been pre-fooked
For some reason this just popped up on youtube for me... that scene right there started my love of early b-bodies
It's not a great movie but you will love his car at the endTHanks, I will watch that.
Broke off in the threaded hole. And yes, it’s bent in the threaded section, looks fractured just under that bottom flangeSumptin don't look right.
like this one looks to be bent in the threaded section
On the other one, it is true that the tension occurs on the threads nearest the tip. That's why full threaded machine screws are not usually needed and just make the bolt weaker.
Was the break inside the threaded hole?
Is there big spacer or bracket?
Threads do not go right up to the cap so that is good design even though its full threaded.
The failure area looks like it may have necked down a little, and the final tear is in reverse direction.
What did Chin think about the very different method?Killed em today running the trotline for the crabs. Caught two bushels in under 3 hours. A lot of really big ones, over 8 in wide tip to tip. There you go Karl..... The smaller ones are in the other bushel. But that one got filled up by the end of our runs. Two bushels and 3 hours is pretty good crabbing.
