Seems reasonable
Eh, I had help. Weird it’s not showing this option in my FSM, granted it is a reprint version from 2001.Looks like you figured it out.
see
You Conduit!
Haha
Weird. What is that diagram page from then? Is that page number in the reprint?Eh, I had help. Weird it’s not showing this option in my FSM, granted it is a reprint version from 2001.
Might be a mid year. Wolfie let me borrow a 64 TSM that had the V8 and Barracuda updates in it that mine did not haveEh, I had help. Weird it’s not showing this option in my FSM, granted it is a reprint version from 2001.
It’s from a digital scan of a 78 power wagon Factory Chassis manual. That page number is in my reprint, but it’s a different section all together.Weird. What is that diagram page from then? Is that page number in the reprint?
Seen that with the '67 parts books. The first releases do not have the Barracuda. Those were added in as supplements, but later printings just included them.Might be a mid year. Wolfie let me borrow a 64 TSM that had the V8 and Barracuda updates in it that mine did not have
Might be. The truck was delayed because of the 400 block problem where they ran out of engines and only had the 360s left. It is a late September build truckMight be a mid year. Wolfie let me borrow a 64 TSM that had the V8 and Barracuda updates in it that mine did not have
Then its almost certainly from the Body Service Manual.It’s from a digital scan of a 78 power wagon Factory Chassis manual. That page number is in my reprint, but it’s a different section all together.
Either way, curiosity has been solved. I’m amazed it’s in such good shapeThen it’s almost certainly from the Body Service Manual.
Do they have those at CVS? I have to go in at 12:30 for a double shot in the arm.
What shots?Do they have those at CVS? I have to go in at 12:30 for a double shot in the arm.
flu and covidWhat shots?
Making mulch with lawnmower sounds better than running a rake by hand!Thought I was done with the leaves. Friggin storm last night blew a bunch up from neighbors into the dogs area. Usually it all blows away from there. Will give it a couple days... If still there, I'll have to buzz them with the mower one last time.
Much better. Wouldn't care at all, except I already blew off the deck and tucked it in tight to the side of the garage.Making mulch with lawnmower sounds better than running a rake by hand!
Yep. I rake very little any more. Just to pull them out from under the bushes. The John Deere does the rest. I blow them all into a windrow and drive over them to grind them up. Then put on the bagger to pick them up. I usually get 2 pick up loads when they are the worst.Making mulch with lawnmower sounds better than running a rake by hand!
I haven't even bagged for last few years. Just get them mulched before they get too thick, and they all disappear!Yep. I rake very little any more. Just to pull them out from under the bushes. The John Deere does the rest. I blow them all into a windrow and drive over them to grind them up. Then put on the bagger to pick them up. I usually get 2 pick up loads when they are the worst.
