Tuesday at 20:00... Feet Wet at approximately 20;19....
In about 30 min. Watching Mike and Molly until game time. Always funny.What's the countdown Mitch?
Screwdriver in the slot and unscrew it out of there. The gear will walk off the cam gearMy search attempts are coming up with garbage...
Tricks for getting the gear out?
Any hook tool to get under the gear?It's off the cam.... still not coming loose....
Trying...Any hook tool to get under the gear?
Probably not.
It'll raise about 2 inches and stop...It went in and turned a million times. it will come out.
Yes. Varnished in I would imagine. Pull up and twist back and forth at the same time.It'll raise about 2 inches and stop...
(Karl??)
Puzzling
Might be hung up on the Oil Pump.....
Like Mike said. Those have close tolerances. Probably varnish built up
It was stuck. The bushing came out with it
Hai Quaaaaa..... Tieng Viet.....
Replace then?It was stuck. The bushing came out with it
