Here ya go. Program in whatever you want. Drivecarjoy-USI like it!
Now that's cool!Here ya go. Program in whatever you want. Drivecarjoy-US
I can see it now. "Get off my ***"Now that's cool!
Morning Mike.Mornining time changers !
LOL for sure.I can see it now. "Get off my ***"
How many squirts per nostril? Wife is seriously bought into BPC-157 and wants to try it in the nose (cue Karl!)
But you're dealing with more than just an hour.Sure nuff... Usually takes me three or four days for my body to adjust either coming to Vietnam or back to America.
The whole yard?Mulch time!
Always start out that way. No point in sharpening till the sticks are gone.Compact tractor, belly mower and last years blades work well!
Yep second day always! Controlled crash to the commode.I just been hitting the legs with a roller and stretching not to bad but feeling the thighs talking getting in and out of the chair this morning...all good!! No pain no gains!!
Didn’t he play for the Cubs? Didn’t know he was in recovery?That's what I end up with... it's not the next day, it's 2 days after.
I started using peptides for recovery. Makes a difference for me
How bout Mary Tucker tho? She rocked it! Two excellent Teams among many. Great match.Congratulations TCU shooters.... Tops in the NCAA for 2024. WVU took the runner up an some individual hardware...
Best at what.I had the pleasure of meeting Tyke this morning. Not to start any problems but he mentioned that he was the best of the group.
Did you install a sill ****? (que Karl) the valves for those are inside the house.So I went over to grab a new shut off valve for the outside water line.
Every year I shut it down and drain it. Every year the copper line would splint. It's an empty line. So last spring I pulled everything and went to pex. Turning the water on and the pex line on the valve pops off. It was fine since around this time last year. Till I shut off the water and drained the system. I give up.
The line runs thru the back wall thru the sun room to outside to the hose.Did you install a sill ****? (que Karl) the valves for those are inside the house.
That does sound a bit muffed up.The line runs thru the back wall thru the sun room to outside to the hose.
The problem is well has been for years.
I had a plumber reverse the direction of the original line it went out side the sun porch to the middle of the house were the hot tub was.
Ir ran out the wall and down along the ground line.no problems ever there
He split it and ran the new line up under the ceiling then down to the hose connection outside. I dig a 200 ft trench and dropped in a line to the back of the property with a hose connection.
I'm going to pull all this in the fall. And run the line down across the floor line with a drain line for next year.
Agree I asked him why cold air rises.That does sound a bit muffed up.
Our old house had water.in the garage and out in a flower garden. I bet someone forgot to drain it and it froze so it was all disconnected. You almost need to trench it in 4' down with a farm type hydrant in the yard.That does sound a bit muffed up.
