Stop in for a cup of coffee
4.88s? your mileage is gonna suck...
OD 4 speed trans will help a little............................
Gear vendor and a change in rear tire size for road use will get you down to about 4 10
I have the Passon 4-speed overdrive Hemi trans.
Ratios, Stock vs. Passon OD
GearStockOverdrive
First2.652.66
Second1.931.59
Third1.391.00
Fourth1.000.80
Effective Rearend Ratios
Rearend Ratio w/ 1.00 FourthEffective Ratio w/ 0.08 overdrive
3.232.58
3.552.84
3.913.13
4.103.28
4.563.65
Really no different, maybe better than my 3.91s. Same rear tire on both cars
For the Charger..... Just need the HP to pull the car to 6000 in top gear......Goal is to crest 200
Morning!
Fricking cold. Almost 0°f. This isnt spring. Thilly me turned off the pellet stove in the shop. Will need to crank it when i fire it up this morning. My mission: pull windshields and start schmearing filler on dash. And take glass into town to get reasonable facsimilies made.
Car is going to annoy the **** outa me.. will be fun til i change gears though :)
you have a 30" tall tire on your car? Pics of your car again?
I just moved the rear springs in 3/4" like 2 weeks ago and the axle back 1" (on a '62 the axle is too far forward and looks goofy...) i could prolly fit a 32" I got 10.5 ET streets in there now.. (295/65/15 i think)
Don't mind the primer... had to make a patch panel there and haven't done the paint yet.. gonna try to match it, rest of the car is original paint still..
Plenty of room on the outer... The spring on the driver side is a bit tight.. passenger has bout twice as much space.. and i don't know why.. i was told by the b-body guys that old b-bodys had insane dimension differences...
