Frodee
Off center a bit
Could I get it signed " Best man for the job"Picture's are $5.00 ea.
Unless you want it signed, $50.00
With a personalized note, depends on what you want it to read.
A Big Congratulations!! Well done to your Son and you for raising this fine young man.
My 65 was floor shift by cable.Speaking of which. I talked to Lon.. that dude that keeps talking about 65 transmissions not being pushbutton, but "column shift by cable" is wrong. I PM'd the person asking the question to clarify after verifying... I'm sure he's confused.. then smacked with the fact that he bought a wide block and not an LA 318
Could be one of my brothers and I paint job if it was a Dart Sport, same hood scoop, made my day seeing it even if its nor a 73 Dart Sport, just thinking of my two brothers and I building it , 340 carSounds too good to be true. Probably a scam.
PlehAfternoon, rain turned to snow here, about 4 inches of snow on the ground.
Awesome.. those the right ones for the car? and how did you "Find" them?
Sorry Dave that sucks.Afternoon, rain turned to snow here, about 4 inches of snow on the ground.
Last time I did my tranny that's what I did. Rachit straps worked real good.K.. Trans is back in the car.. took bout 80 minutes alone and figuring how to do it safe nothing hooked up yet though.. I will say.. whoever posted bout using ratchet straps on the torsion bars to get the trans on the floor jack is a damn genius....
I also kept re-adjusting the straps as i lifted the trans so it couldn't fall if it wanted to... it took sooo much stress off getting it in.. Took bout 15 mins longer than it should have, i couldn't get the right angle between the motor and trans... need 1 more jack.. Will get all the stuff hooked up soon and hopefully fire it up again in a few days
Now I am hungry! Time for supper
Thats not good, hope it melts off quicklyAfternoon, rain turned to snow here, about 4 inches of snow on the ground.
I took the wife out on the road to hit a flea market she has not been to in 5 months, we needed time away, nope, not for my car, need to re home themAwesome.. those the right ones for the car? and how did you "Find" them?
I will have to remember that strap trickK.. Trans is back in the car.. took bout 80 minutes alone and figuring how to do it safe nothing hooked up yet though.. I will say.. whoever posted bout using ratchet straps on the torsion bars to get the trans on the floor jack is a damn genius....
I use a tall hydraulic transmission jack under my car lift....K.. Trans is back in the car.. took bout 80 minutes alone and figuring how to do it safe nothing hooked up yet though.. I will say.. whoever posted bout using ratchet straps on the torsion bars to get the trans on the floor jack is a damn genius....
says the man with a nice lift..I use a tall hydraulic transmission jack under my car lift....
