Reminds me of CR
So this is going to keep me up tonight trying to figure out what CR.... unless it's as simple as Crown?
Reminds me of CR
Pedal I have is smooth on the back with just the hole for the pin/ bracket.Some shade tree mechanic had their hands in there.
The pivot plate should bolt thru the floor. Pedal mounts on that and pivot pin locks it together. For some reason though I believe the pedals are different.
Dang Frank. Should have cut and baled thatCut grass. All of it. Kim was trimming,best friend Ron was on my riding mower and i was on the Kubota with the 3pt mower. 4 hours. Som of it was 30” high.
Did I mention that the cable was held into the pedal by 3 wraps of electrical tape. And they used a lug nut as a spacer behind the support bracket?Some shade tree mechanic had their hands in there.
Mine grow
Kept sliding off and falling on the floor ask Tim.
Yep Crown Royal.So this is going to keep me up tonight trying to figure out what CR.... unless it's as simple as Crown?
Actually I just left it on the floor and pushed where it attached.
I heard you had to keep reaching down and pulling it back into place
17.5 mph increase with the barefoot pedal
See that one looks like it would ride Ok and there is a lip on the ends to keep it locked on. Just not sure about length.
It looks like it is wider then a a body pedal.....See that one looks like it would ride Ok and there is a lip on the ends to keep it locked on. Just not sure about length.
I am pretty sure there is a difference between the 8 and 6 cylinder pedals
It's actually a B C so that's probably trueIt looks like it is wider then a a body pedal.....
Yeah..
I have no idea. I was blamed by a certain poster who’s no longer on this thread. Which is what started the drama between him and I. I had zero idea until after it was done and I logged into nasty grams for itHow did you get blamed? I pointed it out to him when we drove by it!
WhoopsI just discovered I do not have current insurance card in dart. Nothing like waiting till last minute. I can call tomorrow. Grundy car is insured..
Eeeeedddd...... mon.... ton?
Better now that with flashing blues in the mirrorWhoops
You cannot get into venues without proof of insurance...Better now that with flashing blues in the mirror
Yes sir Lets go Oilers!!
