spent bout a hour in the garage.. hit the driver side with some spray bomb gloss black.. it doesn't look as bad as i expected.. will 400 that off and fix some little bits before final primer hopefully tomorrow
That is nice…Thanks that's popped up, here it is closed for traveling and the inside. Perfect for the wife and I.
View attachment 1716272741View attachment 1716272742View attachment 1716272743View attachment 1716272744View attachment 1716272745View attachment 1716272746View attachment 1716272747
Thanks. It is more of an off-road camper for more remote areas, the reason we got it. We had it built in 2017, it is a Hallmark Guanella. Family-owned, and built by them alone, no dealerships. They are in Fort Lupton, CO and you go to their factory for pick-up and installation.Wow, i didn't know they could collapse like that.. soo much nicer on the road... damn man.. i'm a bit jealous
Base weight is 1262, but then options, water, gear etc. I am not sure of exact but a lot less than those huge truck campers. This new truck has the 1-ton F350 suspension upgrade, but I think we will add air bags. We had them on our last truck and makes it nice to level the rear end.How much does that camper weigh? do you really notice it or just settles the back end down a little?
Thanks that is what we are staying in at Carlisle, I prefer it to Hotels.....................That is nice…
i went camping for the first time last year and loved it.. place way up in the UP in michigan.... woman i was with lost her mind.. we drove 6 hours at 90mph.. with windows open and not 1 single word spoken... we haven't talked since... crazy townThanks that is what we are staying in at Carlisle, I prefer it to Hotels.....................
and other guys will hose clamp a spade terminal to tube. I didnt like the gator clamp idea. And some of them are clear coated to keep em shiny.
Thanks, Frank.Took Beetle for a rip. Then forgot it has no brakes
Good luck, Hope it is something simple and you get it squared awayBroke down in Winslow AZ. Fuel issue. Filter I hope but might be lift pump. In tank. And not available
wow that is gold...View attachment 1716272765
Looks like a giant gold nugget.
Hopefully it looks good when it’s all back together.w
For the record I did not choose the colorwow that is gold..
i prefer it to blue... at least it's interestingFor the record I did not choose the color
When it’s back in it should go well with the burgundy. The blue didn’t look good.i prefer it to blue... at least it's interesting
eck yeah.. blue and burgandy would be not great..When it’s back in it should go well with the burgundy. The blue didn’t look good.
How much pressure do the Fords need from the lift pumps? Can you get a like a Carter electric pump to get you going?Broke down in Winslow AZ. Fuel issue. Filter I hope but might be lift pump. In tank. And not available
Great to hear........Tim just called. Turned out it was the fuel
Filters not the pump.
He is back on the road.
Well I think when we build our cars it's more of what we want not the general public's idea on what should be done.For the record I did not choose the color
