Wind chill?Brass Monkeys are in trouble here at 21 degrees
We're down to 18° now
That'll freeze the nuts off a steel bridge.I saw on the news that windchill was in the single digits.
2 1/2 hours ago 75°. Almost sunset, almost 59°That'll freeze the nuts off a steel bridge.![]()
another hour or so.
Put a lower pressure rad cap on it.Nothing broken, top driver side , just splits
Something very few test.Put a lower pressure rad cap on it.
Oooohhh, mr FancyPants, living where it doesent freeze!2 1/2 hours ago 75°. Almost sunset, almost 59°another hour or so.
Beat the heck out of burnin' CA priced gas to warm the defroster for 15 min.
It’s got a 7 psi on it now. Not sure how much lower they make onePut a lower pressure rad cap on it.
I needed a scraper this morning. I wish I knew that then.While I was still working, I kept an empty WD-40 can on the front porch. That rolled seam at bottom of can works great for scraping ice off the Hemi Express windshieldBeat the heck out of burnin' CA priced gas to warm the defroster for 15 min.
Have it tested. Is it mounted with rubber washers on the bolts?It’s got a 7 psi on it now. Not sure how much lower they make one
YesHave it tested. Is it mounted with rubber washers on the bolts?
It’s shot, you can see where the tank has separated from the coreThe radiator I mean
That’s would be convenient for CarlisleI want one of these. Not at that price though. 1954 Cushman Husky Motor Scooter
And fun! UberThat’s would be convenient for Carlisle
And fun! Uber
I had to wear a hoodie today, the grass is still green tho. Weather guessers have us dipping under freezing tonight but back up to high forties again tomorrow. Perfect Winter weather.How cold is it down there John?
Bet you liked my bourbon glass full of wine tho!I'd be plugged up for a week with all that cheese.![]()
