zkx14
Duster De-ruster
Have to find out how you get in? Like can you usually just show up?see!? it'll be SO easy for you to go!
You should probably leave any hand guns and turbans at home.Have to find out how you get in? Like can you usually just show up?
I believe I have given my thoughts about wearing anything with fuzzy-wuzzy on it!You want a make Ben great again hat to wear?
I actually meant the head gear they wear in Saudi Arabia but I don't know what they're called.Turbans are ok silly. This is the new USA!
If the Don shows up I'd get deported.Turbans are ok silly. This is the new USA!
Damn you do good work!In case anyone is wondering what it takes to do an image like this, here's a quick summary. All in it took about 3 hours to complete. If I charged typical Custom Graphic Art prices, this would be a $500 image
First, here is the member's car pic...
Then I found a donor image...
Then I changed the color...
Then I overlayed it on the donor image, adjusted the color and removed the bits that weren't body sheetmetal and extracted the image part I wanted to use (this is the longest part)...
Then I dropped it on a background and color matched the tone and lighting in a merged image (also added the wheels)...
Then I cleaned up the details (painted in by hand) to get the final image...
you'll be first on the listI want one if they do it!
I thought you said Hoppy was already first on the list?you'll be first on the list
I'm guessin that aint the pic going to them.Rock auto magnet with the hello kitty car on it!
