Stop in for a cup of coffee
Took the pop out yesterday for a few miles, dam drivers side valve cover is leaking again, cheap chrome ones. Tried a few different gaskets even the steel core ones, time to find a good fabricated set I believe, just have to be low to fit.
Wow I could actually swing that. Never messed with them does a BB trans hook up to it?
yes sir, a 413 is just an RB block, uses the same block, heads and intakes, accessories etc as a 440. or a 426
Got it Keith, see if he has one. did you see one there?
Yes, its there. Busted up, but I think the part broke out on mine is good on that one. Should just need a phillips driver. I was going to get it and then forgot cause my brain was cooked out there last time. Will probably paint the whole thing then, so I could use whatever to fix this, but easier with a scrap grille to cannibalize.
Doin a quickie brake job on an 08 DTS...But turned out to be a wheel/hub brg also... Disassembled now.. waiting on parts...
Might go put the carb back on the 440 while I wait... IF,IF I can get away from here !!!:lol:
