Stop in for a cup of coffee
Look at 440 source they have some good kits, wish I knew about it before mine went in.
Hey.. I posted this over on the Truck site yesterday morning... 20 views...not one reply...What think you all ??
I have a 92 D250, I bought a while back. Didn't like the way it sat soooo low, so I lifted it (a lot) in the front, using the heaviest D series springs I could find, and A Rubber insulater, claiming to give 2.5 or 3 in lift. Then I added leaf to the rear to make it level.
Been this way for a while now, and when I had my Truck Alignment specialist align it , he told me and showed me that we couldn't get enough camber to make it exactly right. All new upper bushings and joints were installed at that time. Went ahead and left it up anyhow. Now it looks like the camber is getting worse, and I suspect, and have actually looked at the upper arm bushings on my lift, and I can tell, they are wearing bad, I guess because of the geometry. Now I'm also getting a noise on both sides sometimes. I suspect that the bushings are moving all around, and back and forth on the eccentric adjusters, which, BTW are adjusted All the way out. 10k on this set up and not really any noticeable wear on the tires.
Here is my Question. I know I can install new bushings, and it will be ok for a while. But what I really want to know is... If there is someone out there making offset upper bushings to solve this..Or..adjustable upper arms, to give me more length. to help the camber issue.
Anyone got any good Ideas on this....Besides lowering truck back down ???
That 440 will probably be sitting in that car until the GTS,,And the Cuda are done...Probably just fix stuff , so I can drive it some..
Sun is up and the temp is 58 this fine morning :thumbsup: 73 for the high today w3ith no rain in site for the next 8 days :wtf:
Good morning coffee crew, so ! some one test the Alert thing on me please so I can make a report please :)
no site out there moves like FABO ...once you get used to fabo moving so fast, all other sites are boring.
I am also on FMJ and its slow as a snail next to fabo but a great bunch of folks but just way less traffic.
Wonder of the a body offsets would fit?
The truck site is horrible, top poster for the month is sometimes under 100.
a quick Google search makes me think there is not...
Pretty sure , they are too small..
Would I be crazy to take off the upper arms...cut them..and add extensions or gussets to make them longer ??
hell no - not crazy at all.. not many people do 2wd trucks up that high so there is no real market for it... if you have the means - do it to it!
