Ddaddy
I'm changing the World... one pixel at a time!
That's on the 440 six pack.From what I can find the center is a 350cfm and the outers are 500cfm
one word:your altitude is a big factor in air flow and efficiency ...a problem I face here and almost a mile high ...the oxygen just isn't around like it would be at sea level
My plan is working!!!you all best stop, you're making me want a 6 pack for my 440 lol
Yes, but the ratio of total cfm at various rpm is very different for a 4 bbl vs 6x2bbl. On the 6 pack, the low rpm flow is much less than on an equivalent cfm 4 bbl.That is essentially what a 4 barrel does though correct? The primary opens first then the secondaries follow.
TOOI just found this on the same site.
Outboards are 500 cfm, center is 350 cfm. Measured at 4" Hg pressure drop. As opposed to 4 bbl that are measured at 2" Hg pressure drop. Divide 2 bbl figure by 1.414 (square root of 2) to get 4 bbl equivalent (955 cfm in this case).
Ok, that makes sense... kinda.. Im going to have to absorbYes, but the ratio of total cfm at various rpm is very different for a 4 bbl vs 6x2bbl. On the 6 pack, the low rpm flow is much less than on an equivalent cfm 4 bbl.
my head hurts now, thanksWell thank you all for this mind boggling explanation.. I've seriously been trying to figure this out for the past couple of weeks.
yep, imagine that loaded to +pChris, I just watched that video on that ammo. Holy Crap, that is insane. Lehigh sure did make a round that penetrated.
The simplest way to think about it is this...Ok, so because of the delay in opening the outer carbs as well as the jetting on those outer carbs that is how they can run 960cfm on a smaller cubic inch engine?
That does make sense Dave. Why didnt you just say that to begin with??? My gosh you just had to drag it outThe simplest way to think about it is this...
By using three 2 bbl carbs that open at different times and are jetted differently, the total airflow and A/F ratio is optimized so that it is never oversized at low rpm and never flow restricted at high rpm.
It would be like if you could use your 600 cfm 4 bbl at low rpm and then switch to a 750 cfm at high rpm.
LOL! I guess it's the (NUTTY) professor side of me. I always teach students by feeding them bits slowly to get them to think their way through it and find the answer on their own before I just give it to them.That does make sense Dave. Why didnt you just say that to begin with??? My gosh you just had to drag it out
Why would you say that about yourself?? LOL Nutty!LOL! I guess it's the (NUTTY) professor side of me. I always teach students by feeding them bits slowly to get them to think their way through it and find the answer on their own before I just give it to them.
*ahem* it's no secret..Why would you say that about yourself?? LOL Nutty!
