Did Someone Say Haircut ???? I Like Haircuts !!!!
Chili anyone?View attachment 1715027089
Have you figured out the correct angle yet. And don't cut it upside down.
And then tell them if they run around in the shower, they will get twice as wet and can save water by only needing to use half as much...
I wasn't told about the angle needing cut until it was too late.... this is what happens when the wife decides SHE wants to build it but wants you to cut it for her and won't let you see the plans.... tell me to cut a 2x6 to 76 inches, I'm cutting it to 76 inches.....apparently it was suppose to have a 45 degree cut starting at 76 inches
I can always check out.Going to be a long night. Poor M1
Won't let you see the plans??I wasn't told about the angle needing cut until it was too late.... this is what happens when the wife decides SHE wants to build it but wants you to cut it for her and won't let you see the plans.... tell me to cut a 2x6 to 76 inches, I'm cutting it to 76 inches.....apparently it was suppose to have a 45 degree cut starting at 76 inches
the cabin fever effect...Going to be a long night. Poor M1
boom - there it is!!!Won't let you see the plans??
Tear up your man card, it's just been revoked.
all about the POVAngle cut?
Let me re phrase..... there are no plans. She's going off memory off something she seen on PinterestWon't let you see the plans??
No. She can't follow directions, I handle all navigationBet she programs the gps. Or worse driving directions. Just mess in with you carry on.
did he have one?Won't let you see the plans??
a pic is worth a 1000 board ft.Let me re phrase..... there are no plans. She's going off memory off something she seen on Pinterest
And you are following along with this??Let me re phrase..... there are no plans. She's going off memory off something she seen on Pinterest
I hear banjo music playing while this is going on.Let me re phrase..... there are no plans. She's going off memory off something she seen on Pinterest
Apparently.
