Fresh Ice!
I hate stale ice in my drink.
Fresh Ice!
I hear thatGod awful ugly aside. How long before they yellow out or just plain burn. Not to mention the light being redirected.
A wee spot of vodka and strawberry/guava juice.. quite lovely..Whatcha got there?
Woohoooo!!!!!!! Benrita'sAs a matter of fact it is!
A wee spot of strawberry/guava juice and Vodka... quite lovely..
Fixed it.
They're worn on the 'handle' part.If they are worn something is rubbing, never even seen a worn one just bent.
He thinks they're cool and racey. I'm not digging them.
Well, they are LeMans headlights and covers...but they only look good when done right on a certain kind of Vette. His isn't one of them.He thinks they're cool and racey. I'm not digging them.
The red one is pretty tough lookingWell, they are LeMans headlights and covers...but they only look good when done right on a certain kind of Vette. His isn't one of them.
That should be cool, can't wait to see what you come up with!one huge disadvantage of being my size ....is I don't have enough strength to push cars around and move heavy stuff where I want it. So I have to get creative and figure out ways to let a machine do the work
I am going to attempt to build a set up like this to move body shells in the shop
Yep, she's got skillz.That should be cool, can't wait to see what you come up with!
I am thinking harbor freight has the casters ....then I need, maybe a 4 feet of square tube
I already have the plate metal
I would like to do 100. bucks out of pocket and maybe 6 hours of work
Just as an FYI, you can get a set of 4 of these for $108...I think I will build 3 sets ....one set now, built specifically for a 63 to 75 A body car
then later a different set made for B-body wagon size
then a real heavy duty for the polara ...if I ever even get that deep into the polara.
I am thinking the polara is a different deal all together because I am not even sure if the C- body is a full frame or different type set up
New Set of (4) Auto Dolly Car Dolly Wheel Tire 12"x16" Skate 6000lb Repair Slide | eBay
eBay
ever use them? they make it easier by yourself - but still not truly easy..Just as an FYI, you can get a set of 4 of these for $108...
what ones did you switch to? I have that exact issue with mineI have a set of those, fine on a smooth surface. Not so much if you have to run over a bump. Switched my wheels to pneumatic. Cost as much as I paid for the units but easier to roll.
Yeah, I was figuring with these you could use them both with cars on wheels and fabricate some body frame adapters to sit on the dollies when the car is just a shell. I figured it would be pretty easy to fab up some frame adapters that bolt to the dollies when you want them.that is good to know but I am thinking of the ones that bolt to the body with no suspension
I am planning to strip them down that far for paint
like this
