Stop in for a cup of coffee
they started playing it here about a month or so ago - at first I was all WTF is this crap?? now that I have heard it a few times - still can't say it's a great tune - but I don't hate it either
Lead from batt+ to + side of coil. power to starter. cross the solenoid post and voila!!
What about going to the input side of the ballast, and that will feed the coil...
Into the ballast is 12 V, out of ballast is 6 V... Shouldn't the ballast be energized so you don't overpower the coil????
It's different.. Not my cup of tea, but I wouldn't change the station if it came on. And yes, I'd hit it!!!
well, you're not trying to get it running running - just see if it'll fire - I would splash some gas in there and see if it does anything
That's what I did on the Post car with the 440. Turned over, so I pulled the plugs and oiled the cyls. New plugs, splash of gas . Viola...
And this car sat for 4 years .....
Can.. And probably should if it's a melted mess.
well, you turn the ignition key and the blower motor turns on instead of the starter and the fuse block smokes..... with the heat control OFF
If you're running it more than just a minute or two, definitely!!
is there a ballast on a 64 points car? I've never dealt with a points system on a mopar
this one has sat for close to 20 years
Thinkin about postin a Burnout Vid Tomorrow.... If the Brakes hold out... Oh... Yeah... Has open headers Too !!!!:rofl:
