Better you than your kids. At least you still have the use of your thumb, eh?Myself
well that's not enough info - what the heck is going on?Myself
Nah voice dictationBetter you than your kids. At least you still have the use of your thumb, eh?
Yep. Everything came back normal. Even passed the EEG test and confirmed I'm am NOT epilepsicso they have you all hooked up like a lab rat doing tests on ya?
well what the flippin' frick..Yep. Everything came back normal. Even passed the EEG test and confirmed I'm am NOT epilepsic
anxiety over leaving the last job/taking a new one...???
Possibly. I'd have to check. Think I have a set but not sure
Make sure you tell them about the sudden memory return from the other day. It may be related.Yep. Everything came back normal. Even passed the EEG test and confirmed I'm am NOT epilepsic
My first thought too.Make sure you tell them about the sudden memory return from the other day. It may be related.
it appears to be in good condition - but it's been out in the garage (in at least two locations) for a solid 20 years..Kool !!!
I can imagine... yippieeeeei gotta finish puttin a P/S pump on a 2010 Maxima V6... Ya oughta see were they stuck this Bioch !!!!
Check it with a ohm meter first then if you get low ohms ground one side, lick the center and hit the other side on +12vdc you will feel I mean see a spark if it is good! Actually just a plug wire to a ground is good!I'm sure it can be tested...Ax Hoppy ?
