Stop in for a cup of coffee
blasphemy!!!!
Maybe because I paint, IDK, just can't get into the Rat Rod movement. At least throw some primer on so everyone knows it's in progress. lol
Continuing my blocking fun. Found an area that is a bit out a whack. Still needs a little glaze/ rework. Prior to this, I just used rubber blocks with the metal teeth in the ends to hold paper. Really different with these Durablocks. Finds everything. And can actually correct a lot. Amazing how much the thickness of a layer or two of paint can throw off a body line.
Continuing my blocking fun. Found an area that eas a bit out a whack. Still needs a little glaze/ rework. Prior to this, I just used rubber blocks with the metal teeth in the ends to hold paper. Really different with these Durablocks. Finds everything. And can actually correct a lot. Amazing how much the thickness of a later or two of paint can throw off a body line.
Yes it can.
