GeorgeH
Yeah, it has the Rally's. Center caps are real nice, but could use a couple trim rings.is he keeping the Corvette wheels?
Here is the wiring diagram for you...been there done that - Merits S142
I like those wheels better, but yeah about the same car.prolly gonna look lik'em so
that looks like two separate motors.. this is one motor. And the wiring isn't quite like that - what Keith posted earlier was spot on.
dah - - I knew it was missing somethingWhere's the nova hood
Yepdah - - I knew it was missing something
That's what I used on my Barracuda convert. Used a pair of 4 inch round speakers in the front and a pair of 6x9s in box's on the floor in the back. Rears have a quick disconnect in the wires so I can pull them out for shows, or if someone is riding back there. Reason for the 4inch in the front is I also added interior lights there.
Thanks. How does it all sound?That's what I used on my Barracuda convert. Used a pair of 4 inch round speakers in the front and a pair of 6x9s in box's on the floor in the back. Rears have a quick disconnect in the wires so I can pull them out for shows, or if someone is riding back there. Reason for the 4inch in the front is I also added interior lights there.
Dimensions@Ddaddy whered you find those dimensions at the other day? I thought I bookmarked it but can't seem to find it
Dimensions
Length:
195.4 in
Width:
69.6 in
Height:
53.1 in
Wheelbase:
111.0 in
Front track:
58.1 in
Rear track:
56.3 in
Ground clearance:
5.5 in
Turning circle btw. walls:
40.4 ft
Turning circle btw. curbs:
37.8 ft
Legroom:
1st row:
41.7 in
2nd row:
33.6 in
Shoulder room:
1st row:
55.4 in
2nd row:
55.4 in
Head room:
1st row:
37.3 in
2nd row:
36.8 in
Hip room:
1st row:
57.2 in
2nd row:
57.2 in
Calculated EPA passenger volume:
89.5 cu ft
Trunk (cargo) capacity SAE:
14.1 cu ft
It's pouring down rain..... so it's American Sniper time.I should be outside tuning my car...
It's probably because of how it was measured back then. The front seat is adjusted to the mid point of total track travel and then it's measured from the bottom or the rear seat cushion to the farthest point forward that your ankles will go on the floor.That 33 inch number for rear leg room seems big for some reason
IDK if you have power steering or not, but I just ordered the parts to do the "Pump it down" mod from Bergman Auto. I really want to get the over pressure pump disconnected feel out of the steering, but I don't want full manual steering.I should be outside tuning my car...
I did, I removed it for manual steering. I still have my pump and gear box. I've considered putting it back in... Strong arming it is getting old especially with the much smaller Grant wheel. Shoot me a PM when your done and let me know how that goes. Im curious...IDK if you have power steering or not, but I just ordered the parts to do the "Pump it down" mod from Bergman Auto. I really want to get the over pressure pump disconnected feel out of the steering, but I don't want full manual steering.
