Its not everyday you have two cherry old muscle cars lined up on the street anymore! Was epic! I NEED more traction!!!!NICE!
That's not uncommon in performance converters thoughNothing wrong with the way it shifts, just converter gets tighter as it warms up.
spend the $$ on the off set shackle set up - low impact on originality of the car - then get them Keystones on there with MT street radials - it'll hook upIts not everyday you have two cherry old muscle cars lined up on the street anymore! Was epic! I NEED more traction!!!!
I think it got by the censor'soh hell - did I just post that...
heat is the enemy.. that's why racers like to have as much time as possible between rounds.. let 'er cool downThat's not uncommon in performance converters though
Might just.spend the $$ on the off set shackle set up - low impact on originality of the car - then get them Keystones on there with MT street radials - it'll hook up
it'll get some attention in here - sooner or later..I think it got by the censor's
and there it is!!I stepped out to water the new trees. Did I read right? Two old cherries wanting to service a tranny?
Nah, the converter is too light for the application. Needs to be a 3500-3800 stall for the engine.heat is the enemy.. that's why racers like to have as much time as possible between rounds.. let 'er cool down
I have a better solutionNah, the converter is too light for the application. Needs to be a 3500-3800 stall for the engine.
oh yea - that's what - a 2500 in there right Tim?Nah, the converter is too light for the application. Needs to be a 3500-3800 stall for the engine.
You are very spendy...with someone else's money!I have a better solution
T56 swap!
the man has some grandiose ideas for sureYou are very spendy...with someone else's money!
Said the builder....oh yea - that's what - a 2500 in there right Tim?
Based on what you describe, that's probably right. 2400-2800 with heat resistance bringing it down to 2200.Said the builder....
So 3500 stall you are thinking? Hell of a lot less expensive then a T56 swap!Based on what you describe, that's probably right. 2400-2800 with heat resistance bringing it down to 2200.
3500-3800 stall should fit the bill with your engine. Get a tranny cooler too if you don't have one already.So 3500 stall you are thinking? Hell of a lot less expensive then a T56 swap!
You have a way of making things easy for me to understand! Makes total sense.Here's what happens to ATF with temp...
This is why a hot ATF temp reduces stall speed. With a much lower viscosity, the fluid flows faster and more easily causing the converter to more fully transfer the power to the output shaft at a lower rpm. Add in more engine torque and the fluid resistance drops too. That's why the same converter in a high torque engine has a lower stall speed than it does in a lower torque engine.
Yes I do . If I'd ever win the lottery, look outthe man has some grandiose ideas for sure
