with the wife and kids, porta pot is nice!
Let them hang it over the back....
Never looked into them much. Straight in board? Planes faster with less wake with the engine more forward??????? If my memory is right.Master Craft or Ski Nautique are professional water sky boats that they usually use on the competitions... Master Craft uses GM v-8's and Ski Nautique uses Ford v-8's.... Both very good water skiing boats...
Yep, they will be installing blocking. Also, each joist is attached with metal brackets at the cross-support beam which also acts like blocking.Do you have any braces between the joists? IMO you should have. Makes joists tons stronger. Just my observation. Like ths
hey Tim - did you get the email I sent you?Inspector will want to see the blocking tomorrow. It will need to be ready to be coverd and rails. IMO
Let me look.....hey Tim - did you get the email I sent you?
whatd you do? take the chebby hood off and it start workingIT LIVES!!! starts, goes forward and backward - AND stops!!
you got a cat? Say Hello to the Kitty for me.IT LIVES!!! starts, goes forward and backward - AND stops!!
put it back and it kept running toowhatd you do? take the chebby hood off and it start working
she says meow... not sure what it really meant.. but knowing my kitty - you may want to look over your shoulder for a few days...you got a cat? Say Hello to the Kitty for me.
Inspector comes Monday. Blocking isn't required by code, but we are adding it anyway. Only having the metal brackets at the cross-beam is required by code.Inspector will want to see the blocking tomorrow. It will need to be ready to be coverd and rails. IMO
oy - that might be an issue - I am using it for storageNeed inside as well..... M3
That is all good.....This shows how the joists are attached, and how the ledger is bolted through...
Because of the span distance.....Inspector comes Monday. Blocking isn't required by code, but we are adding it anyway. Only the metal brackets at the cross-beam is required by code.
Thought so!.....oy - that might be an issue - I am using it for storage
He just wants to be sure no one can live in there.Tim - can it be stills? or does it have to be video?
