Stop in for a cup of coffee
Oh no I am all alone!
This should help.
Wow really?
Yep. They tried to get me to actually do it. Told them to **** off. Even with a bad back, on Saturday I still came in 10th out of the entire battalion in our ruck march, 10 miles full ruck. We had people without rucks even drop out before mile two and want to give me **** about tapping out this morning.
Going to be hot and humid here today, I really need a ceiling in the shop the heat just radiates down.
Car looks good, hey I would put wax under what you are mounting on though just to get it on there.
Don't even really need that. Get you a roll of that bubble wrap insulation that has nickel foil on the back. Hang it on the bottom side of your rafters. I bet it dropped out shop temps 20 degrees in the summer
Tha
That is what I want to staple up HD has it 255 a roll, I need two rolls the issue is getting it on there it is 16' ceilings so really need to rent a high reach for a day. If I had the extra cash now would be good the shop is basically clean.
If I staple it to the bottom of the trusses it would be flat, they are 48" apart so pretty easy with a high reach.
It does need to be done kills me in the winter trying to heat that space freaking tall.
