ScampMike
Despicable Damn Yankee
I would be super double extra careful - -I have them, I need to run a thread chaser in the holes first. I need to get the correct one, dont have it.
You think?I would be super double extra careful - -
I bet he kept them in a different box so the tires guys couldn't even touch them!!It needs center caps...
Looks good...
I sure the hell did!I bet he kept them in a different box so the tires guys couldn't even touch them!!
well worth it in the long run though - they do look damn good!What a pain the the ***!
that there is funny stuff!!
Agree. Thanks.well worth it in the long run though - they do look damn good!
That works! Will be perfect once you boost the back a little. Will see a little bit of tire above the wheel then. Is it clearing OK where it is?I am going to raise the rear about 2 inches using the shackles DDaddy gave me!
Yes no problem at all with clearance.That works! Will be perfect once you boost the back a little. Will see a little bit of tire above the wheel then. Is it clearing OK where it is?
not bad when you can get 50's all the way aroundYes no problem at all with clearance.
Yep...not bad when you can get 50's all the way around
Sweet!!!
Are those dual pattern?
Looks great! Those shackles should make your ride height just about perfect! (quick 'chop to show what it will look like)What do you all think?
hey ya RamieHello Children!
They are.... 4.5 and 4.75Are those dual pattern?
Jeez took you long enough! You borrow your neighbors Chebbie?Well I made it to Mitches, cold beer, good food and ............
