never had it
You have to eat it when you are on the lam....
never had it
shot ! One shot glass with one ice cube in it then fill..wait about two minutes then shoot it down leaving the ice cubeDo you take it as a shot straight or mix it in your food???
What is 'man lamb'????
Coming down pretty good here. Just had the pup out and scraped off the deck. Forecast says less than one inch and we have about 2 already. Imagine that. LOLSnowing here...
No long nuts, just regular lug nuts. Like factory type...Right. I just know some rims require different style lugs to mount properly is why I ask. I'm just gonna get some lowly non fancy lug nuts.
sweet. I am going to have to get some longer studs. the studs on the polara only go on with these wheels about two threads. not enough to safely hold.No long nuts, just regular lug nuts. Like factory type...
yep!I know a couple guys that are pretty good at streching wheel studs, want me to send em over?
Some of the older stuff had short studs. Good time to make em all rightie-tightey,right?
uh sure!Any of you guys use, want some Old style makita cordless drills, drivers? Free, just shipping. Will check batteries to make sure still good. About 15 Batts, 5 drills...
No, but they were the **** when they first came out. And they had a flashlight that actually worked better than most of the higher voltage ones that have come out since. Had them at work many moons ago - 7.2 volt. LOLAny of you guys use, want some Old style makita cordless drills, drivers? Free, just shipping. Will check batteries to make sure still good. About 15 Batts, 5 drills...
sure.I have a flashlight too, you want Chris?
