Hotchkis is good as well.How about these, not adjustable but...
Hotchkis 79020015: Tuned 1.5 Street Performance Series Aluminum Shocks 1963-76 Dart, Duster, Demon, Swinger | JEGS
is your car lowered ? "*Note: These shocks are better suited for some cars that have been lowered or sit slightly lower than stock. "
I have the 1.03 pst bars in the pop really made it handle a lot better but it is also a 440 and prob weighs 4k or more. Want a rear sway bar, have the towing coil over shocks on it and it actually leaves straight and handles pretty well for what it is just my experience.
A little worn......There’s your problem!!View attachment 1715144141
Looks like a nice job, and a SOB as well....I need to get that hood finished this year so many irons in the fire. It all works just have to do the details! I need some kind of 2x2 plate made up so I can seal it to the carb then trim it as needed, saw one on a guys car and asked where he got it no reply though back! Definitely will never take that on again!
Fiberglass is a wonderful thing...That plenum was a ***** to figure out and 2 gallons of resin prob a gallon shaved off also! Might mess with it today it is nice out and not needing heat. Have to go see the guy down the street and see if he can make me covers for it, not my thing.
Freaking has to weight 40 lbs!Fiberglass is a wonderful thing...
Well you have a 440 brick in there so weight issues have already gone out the door!Freaking has to weight 40 lbs!
A brick with power, but still a brick!Well you have a 440 brick in there so weight issues have already gone out the door!
Yes it is If I ever did it again small block! Cheaper also! Figure 550-600 on this one wont know till the dyno started with it at 450 hp and went from there. (out of a cigarette boat) So yes I have a land yacht I guess!A brick with power, but still a brick!
My 67 440 Dart I gave my brother has nothing on my 408 in this 69. The 408 would for sure kick its ***, strip and street, because of the weight...Yes it is If I ever did it again small block! Cheaper also! Figure 550-600 on this one wont know till the dyno started with it at 450 hp and went from there. (out of a cigarette boat) So yes I have a land yacht I guess!
Again?Do you guys want to see my nipples????
