Stop in for a cup of coffee
Power has been kicking off and on for the last ten minutes. Wondering whats it going to do...
Settled down, power stayed on.
Guess im going to fire up generator later,check the gas.
Wonder if it will run an air conditioner...
Will have to check that.
Depends on several factors but usually no. Not unless it's a BIG generator or one with a heavy continuous load rating
Well after the wrong one,and two defective ones. finally got a compressor that works.
Let's see for how long.
5000 continous.
If it doesent, basement is cool so
Its really a non issue. Was a dumb idea that popped into my head.
More important to run fridge and freezer.
5000 continous.
Worst case is the breaker pops and you reset it.
What is the outer ring around this ball joint. I want to remove it. Other one did not have that ring so was able to get kroil in and came apart fairly easy.
A low pressure media blast? Kinda risky.
Wet sand with 400 would be where i start.
Looks like that was what held boot on.
Got er apart. that's all it was. I was just overthinking it... Brought it in work to put in a big vise. Busy with actual work stuff and started thinking 'what the hell is that for?' when I shoulda just got at it with more power. LOL
You can try denatured alcohol.
Brake fluid or easyoff oven cleaner. WD40.toothpaste.
Actually some bathroom cleaners or cleanser with a soft brush work.
Best to try on a small area.
Think toothbrush.
