Stop in for a cup of coffee
Never thought of cars in the image, but that might be cool....What do you think?
Pettybludart has one on his 66. I like the look.
That's a Dart Sport scoop I believe
Pettybludart has one on his 66. I like the look.View attachment 1715203296
not sure what it was original on, but I know some 72 demons had it for sure. I am planning to use one on my 72 demon and I know it was available new because I have an old ad with it.
It should have been available for more years and more cars because it looks fantastic and looks great on that 66 dart
Dang, I don't know what I did to myself today. I'm a hurtin' unit. Right lower back and right leg pain.
I just did a different image for Tim’s banner. I want to see what he thinks before I post it here.
In the mean time, here is a different one I was working on today...
Finally back from the big city.
Rained pretty much all day.
Streets were slick,put nissan in awd, then it would at least go,light turns green,no spinning.
Printer scanner copier $50.00
I couldnt resist. If the new canon is as good as the old one,i will be pleased.
OK MOPAR buddy called tonight and was telling me the problem he has.
He has a 70 Dart he's spent the past four years doing a ground up build.
Engine is a 360. He's started it a few times during the build and ran fine.
He got the car finished Saturday, and was headed to his first cruise night. Stopped for gas, got in turned the key and got one click off the started and nothing else.
Tried again and again one click.
Had a guy give him a push popped the clutch and drove it home.
He's check the ground all ok.
Put in two different starters and relays same problem.
He tries to start it off the relay with a screwdriver, nothing.
Battery is new and ok.
Checked everything else all appear working properly.
Starter is a mini type that turns quicker and used on the newer trucks...as he explained
He's stumped, thought maybe someone might have an idea.
Saw a lock washer on a starter that was cooked on both sides..
Battery cables,clean and bright.
Put voltmeter on battery posts while someone else cranks,watch voltage.
Same wherever there is battery voltage. Starter,and solenoid wire.
Also test for cranking with a jumper at solenoid.
nss
