yup...the valiant is firsthave you picked which one that will be?
225 Hyper Pak with a 4 speed and 3.91 gears
Snow white with a red interior
Bucket seats, non console (floor Hurst Shifter)
Here's something else that's useful, the water pump from an LA will bolt on, which flows more than the poly pump. However, the inlet and outlet are switched In some applications.That is some gooooood info right there ....Thank you Thank you Thank You
Have funWell all, I will be gone for a few days. Going to Boise Idaho, helping my brother get a trailer from grass valley to there. Later.....
so are you keeping and running the poly in your polara ??Here's something else that's useful, the water pump from an LA will bolt on, which flows more than the poly pump. However, the inlet and outlet are switched In some applications.
View attachment 1715209129 This taken 10 minutes ago. Aparrently clear skies but you can see the haze. That smoke is from wildfires thousands of km’s away.
Alberta and bc. Im in eastern manitoba.
Today is lawn cutting day.... The neighbor's and mine need a cut....
Tomorrow we are meeting my friend Ron and his daughter at the Michigan Dunes for a beach day...
are those poly engines hard to find ....in running condition ??Yep.
Nope. I got a complete running drivetrain for 100 bucks. People nearly give them away.are those poly engines hard to find ....in running condition ??
Actually hold the phoneNope. I got a complete running drivetrain for 100 bucks. People nearly give them away.
Pre67 you can't trust the decoders. I tried that and it said my polara should have a 400... which didn't come out until 72.Actually hold the phone
I just ran the vin through a decoder and it is saying it is an LA 318
In 66 ????
I thought the LA came later
But according to an online decoder
PH23E6 is an LA
In 66 ????
PH23E6 is an LA
Like thisPre67 you can't trust the decoders. I tried that and it said my polara should have a 400... which didn't come out until 72.
Simple way to be sure, look at the valve covers. If it has bolts on top of the valve cover, it's a poly
I can't get the hood open yet, the latch is frozenPre67 you can't trust the decoders. I tried that and it said my polara should have a 400... which didn't come out until 72.
Manual?I can't get the hood open yet, the latch is frozen
Its bent and its going to have to be cutManual?
AhhIts bent and its going to have to be cut
