Stop in for a cup of coffee
Ok I posted this in another thread and no reply, probably should have started here,
I’m not going to be using my heater in/outlets on the water pump housing, at least for now. Can either or both be used as places to put fan switch or temp sensors?
As long as it goes all the way in not in a fitting that will keep it out of the wp housing tried that with a t it gets cooler.
Here's a X block W2 headed 349 cube small block in a 4500# truck. The thing screams!
The bosses with the plugs to drain the water out of the side of the block work also. I just could not use them with the headers.
The pipe plugs on the side. I usually put petcocks in them to drain the crap out once a year. Will give a true temp of the engine water jackets.
Yum!
Just having a couple before I get busy cleaning the bunch of fish I caught today. Don’t want to have too many before handling razor sharp fillet knife!
mudleruckin robbery I say!
Only needed 1, so I got it. Just the 2 tailgate panels on he Magnum have total of 16 of these. Then there is 4 of another style for the piece on the window where the 3rd brake light mounts.I broke 2 and ordered a 10 pack from clips and fasteners for $15 shipped.
If it is not on the site call them with the part number. They only have a bit of what they sell listed.
Fasteners are definitely a rip off. Body shop suppliers have the commo ones in stock also way less than that, needed some other style and think they were thirty cents each instead of 3.00!
I get that, but i’m looking to use(1) mechanical gauge, (1) electric. temp sensor for the FI, and (1) electronic fan switch. For a total of 3. And if I can put them all right there on the water pump housing would make it convenient and clean IMO.
Mark I think I was looking at a thermostat housing that had a bung on it also. Been a while,
