dukeboy440
yep. why i'll never return. 25% tax to rent a car was BSWe pay almost 50 percent of our money in one Tax, Fee, or the other, in The Welfare State. AKA California...
ouch109 at 6pm yesterday in las Vegas...
Sorry, no. Cheap enough for a parts car.
Lots of fiddly stuff.Working on this 70 Duster...Front wheel seals leaking and probably causing wheel lock up. So needs front seals. A few broken studs...WHY ??? Young tire guys dont know LHT lugs...LOL Master cyl looks like $hit, so gonna replace that. Engine needs tuning. Fuel tank is leaking, probably from tank ring...Yada Yada Yada...
Duh!Oh. Yeahhh. Look how this exhaust surgeon ran his tail pipe !!! Rear brake hose on HOT pipe....NICE.......
View attachment 1715210847 View attachment 1715210848
Genius! Brake fluid heater for them D.C winters!Oh. Yeahhh. Look how this exhaust surgeon ran his tail pipe !!! Rear brake hose on HOT pipe....NICE.......
New home! The old one was the original and had some rust pits.
I don't see why not.Ok I posted this in another thread and no reply, probably should have started here,
I’m not going to be using my heater in/outlets on the water pump housing, at least for now. Can either or both be used as places to put fan switch or temp sensors?
Sure....Ok I posted this in another thread and no reply, probably should have started here,
loop them and put it between ...Ok I posted this in another thread and no reply, probably should have started here,
You could but what I'd do is loop them, then get a T fitting for where the temp sensor is from the factory, which will allow you to run two temp sensors. The later is what I did on my 408Ok I posted this in another thread and no reply, probably should have started here,
I get that, but i’m looking to use(1) mechanical gauge, (1) electric. temp sensor for the FI, and (1) electronic fan switch. For a total of 3. And if I can put them all right there on the water pump housing would make it convenient and clean IMO.You could but what I'd do is loop them, then get a T fitting for where the temp sensor is from the factory, which will allow you to run two temp sensors. The later is what I did on my 408
