zkx14
Duster De-ruster
Yeh I know, Been there, seen that. lolJust been doing plenty of welding. Mitch has a few other cars he's playing with over there.lol
Idk, it might have been old gas out of my boat or it might have been K-1. Bang, chug, bang, chug. LOLIf it killed even a few of the bloodsucking bastards, You should get another can full of the stuff. lol
two stroke mix?Idk what was in that gas can of mine, but the mower just fogged 2 acres for skeeters.
Could be, my brother in law was messing around with weed eaters and stuff a few weeks ago and might have set up the can of gas for that.two stroke mix?
They are showing T-storms here for later Sunday, but only 40% should be good for the most part. Looks like some heat rolling back in for the week. Getting up around 90. Just hope it doesn't turn into another round of oppressive humidity with 100+ heat index. I have a deck rebuild project I am doing. Been getting there a couple days a week for a few hours before the 'real' job. So far re-inforced the structure and have the rail posts up.Planning to pull the car out for an autocross at the stadiums on Sunday. I know Sunday will not be as nice as Sat but it shouldnt be too bad.
Thanks for the heads up. I'll check some forcasts this afternoon. I'm OK with rain. T-storms less so.They are showing T-storms here for later Sunday, but only 40% should be good for the most part. Looks like some heat rolling back in for the week. Getting up around 90. Just hope it doesn't turn into another round of oppressive humidity with 100+ heat index. I have a deck rebuild project I am doing. Been getting there a couple days a week for a few hours before the 'real' job. So far re-inforced the structure and have the rail posts up.
Sounds about right!If by 'caught up' you mean read part of every post with one eye open before coffee with little comprehension...
@krazykuda appreciate the offer but I couldnt accept that even if you did have the time. That's a heck of a drive to come help my stupid ***
Man it is quiet here this AM. Wake up it is TT after all!
If I had the time, I would do it.. You're only about 2 1/2 hours away from me...
We could get that car rewired properly and it would last a long time... I like to solder as much as I can for durability and a robust connection, even the non-solder connections get soldered when I do my wiring...
I wire to make it last as long as possible..
If I spent a day with you teaching you how to rewire a car, you would learn enough to do it all yourself...
If I could find the time to go down there and we had all the supplies, we could make a good dent in the wiring or get it all done...
I'm still trying to see if I can work it out in my mind....
Plus, we could finally meet in person...
Well first casualty on the Barracuda, Stan was taking the bucket seat on the passenger side out and hit the arm rest and broke the base.
Rookie move
Got to love the old school stuff though!
I'd run them unless there is some issue. If you can't get decent linings Firmfeel carries a semi-metalic lined shoes, Porterfield and Rochester Brake will reline and arc.
Beautiful weather here. Supposed to last through tomorrow. Gonna do a show with the Duster tomorrow, just a few minutes from home at a shopping center. Will get moving here pretty soon and give Cinnamon a sponge bath.
So in repairing rear brakes,heres what i found.
Rear steel brake line leaking, loose nut
Diff cover leaking,loose bolts.
Left axle seal not driven in all the way.
Right spring u-bolts loose.
Im not letting him fix his stuff anymore.
