Stop in for a cup of coffee
Happy birthday Pete
Abs wont put up codes on the dash, but i gather you already expected that. A lot of the bearings have sealed sensors/ tone rings, washing may not change anything.
I cant see where the ring is, so not sure if my pressure wash got to it. Is that on all 4, or just fronts ? I had it up on ramps and blasted from inside/under the best I could. I tried it when I got home at midnight and again this morning. No problem. So tonight I won’t mess with it and see if I get same result in morning.
Did a little damage control on the Duster this morning. Nature is working hard to undo my previous efforts. Filler was bubbled/lifting in a couple places. Just got anything loose off. Wire brush and rust reformer primer. I need to look at my old photos, but am near certain these holes are in metal I replaced. I think I came up just under the body line… Kinda disgusted with this thing. :BangHead:
We all get there
We all get there
I've done enough patch jobs, so not a huge surprise. 'rust never sleeps' Just hoped it would last longer. I did repairs many years ago with not even close to the prep work here, and lasted a long time. Gotta wonder if some of the materials just aren't as good with environmentally friendly reformulations. At least I'm not swapping failed drive trains, right? :eek:
least it's not in a bad spot... looks like a pretty quick fix
Read through a bunch of SlantSix Dan's threads on LED lights and took the plunge since I have to put the headlamps back together and I'm going to build a new gauge cluster anyhow. Hope it they don't suck
Afternoon people, still snowing here and not supposed to stop until tomorrow afternoon.
They are gonna be awesome
The only part on 66 i did not rebuild myself. Transmission...
