Having a shot of Revel Stoke whisky for Memike.
HA!!! this is turning out to an awesome Friday night
I have been banging my head against the wall trying to figure out what is wrong with the clutch in my 69 dart.
The clutch fork kept coming off the throwout bearing and then you would press the pedal in and it would move the linkage down to the fork but the fork wouldn't move the throwout bearing in.
I thought pressure plate?? throw out bearing itself, even tried two different ones.
even tried a different clutch fork from another car.
turned out to be the pivot was bent and I have no idea how it got bent outwards (used parts)
it was bent outwards just enough to be a problem but not enough to be obvious at first glance.
tried a different pivot from another car and problem solved.
Congrats of the fix m'lady. Always great to finally find the root of the problem and end the frustration. I think the burger might have provided you the inspiration!
Any chance you got a 318 flywheel floating around in your massive inventory af cool mopar stuff?
300 bones is a lot of jack.. that's why im shopping slow and early. See if i can find an od bell housing and a flywheel without taking out a second mortgage. I do love my cars to have 3 pedals...
I just checked and brewers has a listing for one at $279. but it shows out of stock which doesn't surprise me after what I went through to get one.
a used one is probably going to run 2 - 250. IF ....big IF you can find one
I hope I am making you sad now lol
I gof a couple yards our here and every now and then they turn up. It's just matter of leaving work long enough to get the stuff. Actually had a yard crush a 74 duster during our busy season. 8.25 disc brake car. Could have had all i could pull for 150 bucks. Just couldn't leave work. Enough to make a grown man cry.
Im beginning to think you're evil!
Got a teen and a 904 to slide in for now. Want to convert that to od 4 speed with 3.55 rear. That drivetrain will eventually go in a duster or dart sport. I have a 340, 4 speed and 8.75 w/3.91 that will end up in the notch. Seems like that leaves me 2 really fun cars. With the scout and a motorcycle, i should be pretty well set.
Too soon to be drinkin?
Get over tHis one and you ar an ace rani! Lmao!
lOOKS LIKE A SPOONING COON TO ME!
