It does have that Themoquad moan at wot, couldn't hear it on my van but my sons car with the 625 on it you sure can.
Mine is loud as HELL in this big heavy truck. lol
I hate wide LSA cams. But if you have too much compression, sometimes they are the lessor of two evils
I'll show you what I mean.
First
If you grab that little lever, it should move freely, pulling it forward and pushing it back, if you crack/open the throttle normally with one hand, and grab that ford lever with yer other, it should move freely as you open the throttle to wide open. A while back I got on the throttle hard doing some showboating and went down the road. As I let off to come to a stop the thing kept on reving like a stuck throttle. I whacked the throttle and it dropped back down. Looking at it I discovered that lever was tight on its shaft, but the part sticking up was maybe rubbing on something?? (I'll have to look at it again to see which) causing the throttle to hang up. Lube didn't help. It was too tight, so I just hacked it off. Maybe a production flaw who knows but freaked me out at the time it hung up!
Well that sounds like the right way to do it. My fix was a hack, and it looks like one, but it solved the hangup.I got mine cut off today. And I mean SLAM cut off. I disassembled the primary throttle shaft and cut the WHOLE thing out from around the throttle shaft. It was more in depth than I wanted, but that fixed it. lol
Could you possibly take a picture of this haircut you gave your carb? (Please)
I think I know what you did but, not sure.
Maybe those reading are interested too
Thanks for your input !
Sure, but it's hard to see. It was the phord transmission kickdown lever right behind the regular throttle lever on the carburetor. I'll get you a picture when we get back from town.
Gottcha! thank you !! those phords.....
Just ordered the Street Demon 625 and the throttle adapter from Summit, 10% off plus another $25.00 discount and free shipping. Seemed like a good deal.
My last engine was a 500 stroker, built with torque in mind, using a 750 Holley DP. My previous engine was a stock stroke 400 using an AFB. It was a very flexible street combination that made 450 ft/lbs of torque and 415 HP. The AFB ran well, but I hated the constant smell of gasoline in the garage as the fuel boiled out of the carburetor. The Holley solved that problem. I am now looking at building a slightly detuned version of the 400 I built, which will be easier for long distance cruising with a tall gear. I know there are trade offs, and I am not expecting Toyota mileage, but I think I can find a happy medium. Time will tell.
Are you skeptical of its performance? I wouldn't be. Get it dialed in it may surprise you, especially its responsiveness. And as compared to other similar sized carbs it can hold its own, and may be better than many.....on the street, and impress at the strip. I've run the SD 750 on the street and strip, as well as an AED 750 DP. The Street Demon is a good performerI received the Street Demon carb yesterday. It is a very nice piece, but I have to say that the throttle plates look smaller in person than in the pictures. The primaries are really tiny, and the secondary is really not any wider than a conventional square bore carb. Now I can see why they say that it will fit on a square bore manifold.
I have the 703 cam in my 340 and it pulls 15 inches, its a larger cam so you should get your vacuum. And it has good bottom end, but I am running 3.23 gears with 28" tires.The idea was a 2.94 gear as a low budget alternative to a lower gear with an overdrive. Again the cars I am looking at turn out to be stretching my budget, so I am trying to work out cheaper ways of meeting my goals. For a cam, the lunati voodoo 10230701 looks good to me 213/220 duration 454/475 lift 112 lsa. Claims 19 inches of idle vacuum and a 1000-5500 range.
Yes I was probably a bit skeptical after seeing it in person, I guess I was comparing it to my old 750 DP. The numbers work, so it should be what I need. I have to keep reminding myself I am not building a drag racer this time.Are you skeptical of its performance? I wouldn't be. Get it dialed in it may surprise you, especially its responsiveness. And as compared to other similar sized carbs it can hold its own, and may be better than many.....on the street, and impress at the strip. I've run the SD 750 on the street and strip, as well as an AED 750 DP. The Street Demon is a good performer
Yes, I was planning on doing that before I install it. Likely bounced around a lot during delivery.Remove the top and check the float level before install. Mine was off.
