I say fuel system. Lack of sufficient fuel volume.
I hate to agree with the old git but Cracked is probably right - I've had asimilar issue.
Also - if it was hot, then id say vapour lock - but you guys are not getting those kind of temps.
While that is truly the best place to be and where I allways wanna be, truth is, it doesn't happen like that all the time. I do try and brush'em off, but every once in awhile..............
Just to clear the air I do realize that racing on non sanctioned roads is not a good idea, however anytime my group of weekend buddies and I get together it happens and we feel we go about it in about as safe a manner as possible. We are ALWAYS in the country or in an industrial area away from innocent people and homes. Anyone who is at a spot with us is there because they chose to be, nobody is forced to do this and we assume full responsibility for our actions, at most we may hit a deer. I know it's not the best thing to do but it is a rush and always was/ will be. What are some of the most infamous mopars? Jimmy Addison's Silver Bullet and Big Willie's Daytona, both extremely active and popular street racers from the day. Call us stupid if you want but we are never under the influence of any substance (excluding sun drop and pizza) and we've got roads prepped better than some tracks. btw if you need a cheap test spot pour some corn syrup on a road on a hot day in line with your tires and in a few hours you've got a great launch pad. One more time
STREET RACING IS NOT A CRIME. . .well it is but, **** it.
(steps down off soap box and wishes a good day to the kind FABO members)
Thick or thin?
I'd run through all the ignition after that and then look into the carb. Possible dirt in there hindering performance.
Thick or thin?
If you roll out of it, then roll back in does it pick up? If so, it's was likely out of fuel. The pinging was from it most likely going lean.
Is it hot, like maybe vaporizing fuel?
STREET RACING IS NOT A CRIME. . . well it is but, **** it.
I had a similar problem, car would fall of and ping at the top of 2nd at the track... I could never reproduce it after cause I wasn't running it at WOT for as long (Stop, 1st, 2nd) on the street.
Mine was 2 things, Orange Ignition box (the chrome is for higher RPM) and insufficient fuel pump for demand. (good PSI, but not the volume, needed bigger line and aftermarket pump)
goodluck
JOE
R/fish............I'm with ya man!!
circa 1981
corn syrup 8) Sounds cheaper than VHT :cheers:
circa 1981
Maybe dirty sock filter in tank.....?...or regular in-line filter?
circa 1981
