Your problem might be as simple as the choke pull off is shot, not opening the choke when the engine starts. Then it floods the engine.
You need to start the car cold with the air cleaner off. Press the gas pedal to the floor ONE time, then check to see if the choke really is almost fully closed, just a tiny bit of clearance. There is a specification, but I can't find it now.
I'd bet it's in here:
http://u225.torque.net/cars/SL6/docs/Carter_BBS_Service_Manual.pdf
If the choke plate is right, start the engine and watch what happens on the carb. When the engine starts, manifold vacuum starts to pull the choke plate open if the choke pulloff is functioning. If that doesn't happen, the choke plate will remain mostly closed, the engine will run rich and you'll soon have a black sooty patch on your driveway. Hope that helps.
BC
Ditto on the "choke pull-off" or "unloader". I am guessing you don't know what that part is since "choke sticking" isn't the same. Look for photos. It is bolted near the top of the carb, with a short linkage to the choke plate and a vacuum tube from the bottom of the carb to it.
They often go bad (carb cleaner ruins the rubber diaphragm). Besides the steps above, a good way to test one is with a hand vacuum pump. Without that, the "poor man" method is to disconnect the vacuum hose, push in the plunger, block the tube with your finger, and see if the plunger stays in. If it moves out, the diaphragm is bad. Costs <$10 and makes a big difference in easy starts and avoiding "dying rich" on cold mornings.
As soon as i can find an affordable OEM shop manual, I'm reading it cover to cover! ,
In the meantime, you can get one for free.............
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
Ok... me again. Yes, I see I'm still in the right place.
One other even quicker check of timing chain -- does your timing mark bounce around a lot at idle? That could be a tip-off of slop there.
I'll quit now.
Sleepy, I am,
JD
Ok quit flopping around like a fish out of water, LOL
You say you "checked the spark" and there was NONE
STOP RIGHT THERE
Just exactly what did you do to accomplish this? Details of how you did so?
Now if there REALLY was no spark, that should have been a giant clue.
The very first thing I would have done is get out a clip lead, hook from the coil + terminal to a battery source, and re-crank and re-check for spark, and go from there.
You cannot just wonder. You cannot just guess. You actually have to CHECK some of this stuff. Now I realize that if this is a sometime thing, otherwise known as "an intermittent" this can be difficult.
Early timing gears have/had plastic caps/covers on cam gear teeth some of these may be coming off and affecting timing drift.
Do you know any history on this motor?
When I got it home I checked more specifically by pulling the middle distributor wire free and seeing if it arced against the breather case,.
At the risk of speaking out of turn, I am pretty sure the cam post was talking about the "timing chain" slipping a tooth on the "camshaft gear", nothing to do with the distributor internals. A skipped tooth can happen if the gear is greatly worn, or an old and brittle original nylon gear (used on some early cars).So the previous poster was correct that the cam was slipping [there was heavy wear on the distributor shaft,
What do you think? Am I on to something?
