blano86
Member
I am a total newb when it comes to fixing stuff but I no enough to know there is a problem. I have a 340 in the 1967 cuda notch.
I may have a stuck valve. I was driving when all of a sudden the cuda started to lurch and back fire thru carb and tail pipes. It ran okay if I accelerated but when I let go of throttle it back fired and it would backfire when I tried to accelerate from idle.
I checked each cylinder, by removing spark plug wires at the block one at a time to check to see if it would miss when I removed them. Every cylinder seemed to miss when I removed wire. My thinking was that if a cylinder had a stuck valve it would not make a difference when I removed wire. I drove it again and about a half a mile down the road it started to act up again.
I removed the valve covers and could not visibly see any problems.
From the pics below could anyone tell me which heads I have? I thought that rockers were adjustable? A compression test would probably help a lot too, but I do not have one on hand. Is there anything else I can check to see if a valve stuck?
Here are some pics of the heads and valve train:
