the block is stamped ' hm 340 r '. I think it is a 1972 340. It was not raining when it started to act up. I looked at the timing chain today and it is what i think is a dual roller chain? It has metal gears. It looked fine. Since i tore it down that far i am going to have it rebuilt.
I think the 340 is totally stock, and i want to add some more horses with out changing too much with the rebuild. Does a little more radical cam cause me to get new rockers etc.? Remember i am a newb!
you can put a somewhat bigger cam in it without changing the rockers but there are limits to what the stock rockers will take plus there's the known issue of them not being very accurate on their ratio. A good set of aftermarket rockers (no cheap chinese junk) is a good upgrade. also remember the valve springs will have to be changed if the cam is.
another issue is how much for a rebuild?
that can't be answered very accurately by us since we can't see the engine and the shape it's in (what's worn in what areas). Plus machine shop prices vary accross the country so it may be $2000 here in il but in ca it may be $3000.
i called a local machine shop that has some good reviews and they said they could do a long block rebuild for about $2,000. Also they said a valve job would be $548 for both heads. Is that too much or a good price? Should i just let them do a short block? I have a friend who is a lot more mechanically wise, so he could help me with the short block.
depends on exactly what they consider a "total rebuild" but generally $2000 for a long block and $548 for a total rebuild of the heads is a decent price. ask them what all that entails and post back what they say and we can say more.
does any one have any tips for a rebuild for a 340 that is stock? Any ideas for extra horse power without replacing too many parts (radical cam = new rockers/lifter/springs)?
buy yourself this book, read it cover to cover and you'll learn a lot.
http://www.amazon.com/dp/0895864797/?tag=joeychgo-20
another issue is ethics. Do i need to take any precautions before i hand over my 340? Like take vin numbers and numbers on parts such as heads? Should i be worried about this? How will i know that my crank went back in the engine? Any pointers will help.
i guess it wouldn't hurt to record the numbers considering all the crooks out there but if you have real issues with trusting them maybe you should find someone else.
sorry for all of these questions, but this is what i have been thinking about. I have never had an engine rebuilt.
Thanks to all that have responded with their thoughts.
